Update Working
Thread begun 5/20/2016 5:44 am by stevenmcgough | Last modified 5/20/2016 10:23 am by Ray Borduin | 1167 views | 1 replies |
stevenmcgough
Update Working
I have a very simple page as way of a test which is not working with an update. I followed the steps to create this and the resulting code is :
<?php require_once('Connections/PWS_Conn.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
$RS_PWS = new WA_MySQLi_RS("RS_PWS",$PWS_Conn,1);
$RS_PWS->setQuery("SELECT * FROM pws_clients WHERE ID = ?");
$RS_PWS->bindParam("i", "".(isset($_GET['ID'])?$_GET['ID']:"") ."", "-1"); //colname
$RS_PWS->execute();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$UpdateQuery = new WA_MySQLi_Query($PWS_Conn);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "pws_clients";
$UpdateQuery->bindColumn("Fname", "s", "".($RS_PWS->getColumnVal("Fname")) ."", "WA_DEFAULT");
$UpdateQuery->bindColumn("Lname", "s", "".($RS_PWS->getColumnVal("Lname")) ."", "WA_DEFAULT");
$UpdateQuery->addFilter("ID", "=", "i", "".($_GET['ID']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "updated.php";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<link href="css/pws.css" rel="stylesheet" type="text/css">
</head>
<body>
<div class="form-style-8"><img src="assets/emails/pws_logo.png" width="126" height="127" alt=""/><br>
<br>
<strong>Welcome<br>
<?php echo($RS_PWS->getColumnVal("Fname")); ?></strong></div>
<h2>Register for the VIP EVENT</h2>
<form action="" method="post" name="ClientsReg" id="ClientsReg">
<p>
<label for="Fname">First Name:</label>
<input name="Fname" type="text" id="Fname" value="<?php echo($RS_PWS->getColumnVal("Fname")); ?>">
</p>
<p>
<input type="submit" name="submit" id="submit" value="Submit">
</p>
</form>
</div>
</body>
</html>
BUT - it redirects to the updated page - but the record has not been updated...Any help would be appreciated
You have it set to update to the current recordset value, which isn't an update at all since it is setting it back to the original value.
Open the Update server behavior and bind the column values to the form fields not the recordset values.
