Currency set to YEN submitting USD
Thread began 5/17/2016 5:26 am by brianw101189 | Last modified 5/18/2016 10:10 am by Ray Borduin | 2163 views | 4 replies |
brianw101189
I have setup the Currency as YEN in Ecart. It shows up fine in the shopping cart, but when it processes thru authorize.net it tries to charge the YEN amount in USD. Any help would be great. I'm currently using Ecart 4.52 I believe.
Find the line that refers to: "x_currency_code" on the confirm.php page.
You should be able to change the currency code on the line below that.
brianw101189
There is no x_currency_code anywhere on the confirm page?
brianw101189
Ok, I found that in the code, but now get an error. It appears authorize.net doesnt convert/allow the YEN? Do you know if that is correct?
That is correct, Authorize.net will only transact in the native currency of the bank account it is tied to. You would need a Chinese bank account and merchant account to transact with YEN using Authorize.net.
