update order
Thread begun 5/12/2016 3:40 am by Jamie | Last modified 5/17/2016 10:18 am by Ray Borduin | 3586 views | 8 replies |
Jamie
update order
Hey Ray
Am trying to re-order product results based on the products category.
Have set up a page which displays the product results based on the relevant category id however, I cant get the update order to work
It doesnt update the ProductOrder and it doesnt redirect to itself...
Have attached and any help greatly appreciated
Jamie
This looks overcomplicated... I think you can just use this code in place of lines 51-71:
if (isset($_POST["UpdateOrder"])) {
mysql_select_db($database_PowerCMSConnection$PowerCMSConnection);
$OrderArray = array();
$start 1;
    while (isset(
$_POST["ProductID_".$start])) {
mysql_query("UPDATE products SET ProductOrder = "intval($_POST["ProductOrder_".$start]) ." WHERE ProductID = " intval($_POST["ProductID_".$start]), $PowerCMSConnection) or die(mysql_error());
$start++;
You will also have to add that ProductID hidden form to your repeat region... something like:
<input name="ProductID_<?php echo($curOrder); ?>"  value="<?php echo($row_WADAproduct_order['ProductID']); ?>" type="hidden" >
If you want to set up a premier support ticket I can show you how to do drag/drop reordering at some point.
Jamie
thanks Ray. Its still not working ( not sure if thats because its still not redirecting to itself?) attached is the updated file EDIT. sorry should have said that it needs to redirect to itself using productorder_results.php?CategoryID=<?php echo($row_WADAproduct_order['CategoryID']); ?>
re the drag to re-order, I would love that at some point :) got a list am building ready for a ticket.
Change the form action to action="" and it should maintain any necessary url parameters.
It looks like it would work to me at this point. I guess you would have to debug where it is going wrong.
Add a die() statement inside the IF to see if it gets to that point. Then die inside the while to see if it gets in there. If it does, then die with the SQL statement you are running and see if it looks correct.
Check your page for the hidden form element and make sure it looks like it is named correctly. There is an issue somewhere but I'm not spotting it. Probably something simple once you figure out where it is.
Make sure you add " ORDER BY ProductOrder" to your main recordset. As it is, you wouldn't be able to tell if the order was updated in the database or not since you aren't changing the order on the page.
Jamie
Have checked all those and it all, as you say, *lloks* good but it just isnt setting the order
Did you try debugging? What happens if you update the re-ordering code to:
echo("on top ");
if (isset(
   echo(
"in if ");
$start 1;
var_dump($_POST);
    while (isset(
    die(
"UPDATE products SET ProductOrder = "intval($_POST["ProductOrder_".$start]) ." WHERE ProductID = " intval($_POST["ProductID_".$start]));
$start++;
Jamie
thanks Ray. On top shows fine, but in if doesnt
I think this may be the issue with using <button> tags instead of <input> in your form. This should be fixed in the latest version of databridge but in the mean time you can just replace the file:
webassist/progress_bar/jquery-blockui-formprocessing.js
with the one I have attached.
Jamie
OK Ray will try that. Thanks for all your help and input :)
