Quantity field and Weight dynamic select list don't pass data to cart.
Thread begun 5/10/2016 9:20 am by tmcbinc99963 | Last modified 5/13/2016 10:24 am by Ray Borduin | 5626 views | 9 replies |
tmcbinc99963
I've added a quantity field and dynamic select list to an existing DataAssist product results page, but can't get any data to pass to the eCart page.
Also, I need for only the product(s) that have entered values to show up on the eCart page.
Shows 'cart is empty'.
Files attached.
Since you have your form fields in a repeated region, you will need to make sure they are named uniquely. Do that by appending the productID column from the database to each like:
name="“eCart1_1_Quantity<?php echo($row_WADAProd['ID']); ?>"
Then, since you are adding more than one item at a time you would have to remove the "Add to Cart Button" server behavior and instead use "Get Cart Contents from Recordset" which can be used to add more than one row at a time.
When you bind the values in that interface you will refer to the form elements with the appended productID so that you can get the appropriate setting for each. It will automatically ignore any rows whose quantity is not set or is set to zero.
tmcbinc99963
Added the following to each form input:
name="“eCart1_1_Weight<?php echo($row_WADAProd['ID']); ?>"
Deleted the Add to Cart server behavior
Opened the Get from Recordset server behavior and changed bindings to:
Same result as before: cart is empty
Files attached.
Your form field names have extra quotes in them...
should be:
name="eCart1_1_Quantity<?php echo($row_WADAProd['ID']); ?>"
Then the corresponding binding should look like:
<?php echo($_POST['eCart1_1_Quantity'.$row_WADAProd['ID']]); ?>
tmcbinc99963
Removed the extra "
Opened the 'eCart Get From Recordset' server behavior and replaced the binding for both quantity and weight.
Still says 'cart is empty'
Files attached
You have your form action set to post directly to the RequestforQuote.php page. You need to submit to the current page and redirect to the RequestforQuote.php page after it adds to the cart.
Change your form action to: action=""
tmcbinc99963
You mentioned changing the action in an earlier post, but it returned the following error message, both then and now:
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/websitename.com/Connections/ProductsDb.php:9) in /Applications/MAMP/htdocs/websitename.com/Prod_results.php on line 190
When you say 'redirect to RequestforQuote.php page' do you mean add a link to the submit button? This change has been made to the attached files.
This implies there is an error message generated on line 9 of /ProductsDb.php, or there is a blank line of code there that needs to be removed.
tmcbinc99963
It looks like there's a conflict with the eCart redirect 'header' line and the ProductDb.php file. Both lines of code are cited in the error message.
// WA eCart Redirect
if ($eCart1->redirStr != "") {
if (function_exists("rel2abs")) $eCart1->redirStr = rel2abs($eCart1->redirStr,dirname(__FILE__));
header("Location: ".$eCart1->redirStr);
die();
ProductsDb.php file attached, with others.
You can't redirect a page after an error has been written. My guess is that your database connection is failing on line 9 which is causing an error message and then the redirect error is just a symptom. Are you sure your database information is correct and your database server is up and running?
