DA Update Record displaying server behaviour
Thread begun 5/06/2016 1:57 pm by Kumel | Last modified 5/06/2016 7:01 pm by Ray Borduin | 651 views | 1 replies |
Kumel
For the following DA Update Record isn't showing on server behaviour panel as i need to edit this.
// WA DataAssist Update
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $con1;
$WA_table = "MutipleEmployees";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "ID";
$WA_fieldNamesStr = "Status";
$WA_fieldValuesStr = "".((isset($_POST["completed"]))?$_POST["completed"]:"") ."";
$WA_columnTypesStr = "',none,''";
$WA_comparisonStr = "=";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_where_fieldValuesStr = "".((isset($_POST["ID"]))?$_POST["ID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode($WA_AB_Split, $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_con1;
@session_start();
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
Can some modifications on it make it appear on server behaviour panel?
It looks like this line got deleted:
$WA_redirectURL = "";
It should be just after this line:
