Sending Emails to selected employees
Thread begun 5/05/2016 2:35 pm by Kumel | Last modified 5/06/2016 6:50 pm by Ray Borduin | 4858 views | 13 replies |
Kumel
I have form where we choose employees (checkbox) & i want to send them a email when form is submitted.
i can share ftp details to take a look at codes.
Thru this we get employee id which is used to store in mysql.
<input name="Emp_<?php echo $RepeatSelectionCounter_2; ?>" type="checkbox" id="Emp_<?php echo $RepeatSelectionCounter_2; ?>" value="<?php echo $row_UsersMachines['ID']; ?>" />
Above hidden field contains Users 'ID' How to send them emails to selected checkboxes?
You can filter a recordset with the checked values using the Database Search server behavior and then send the emails to the recordset results.
Kumel
u mean using existing rs which are resulting list of employees?
Kumel
how to filter a recordset with the checked values ?
DataAssist Search has a "list" search which you can use to filter based on a checkbox group. Just name the checkboxes with the same name and make sure the name ends with []
Kumel
this is my checkbox: <input name="Emp_<?php echo $RepeatSelectionCounter_2; ?>" type="checkbox" id="Emp_<?php echo $RepeatSelectionCounter_2; ?>" value="<?php echo $row_UsersMachines['ID']; ?>" />
will it be: " Emp_<?php echo $RepeatSelectionCounter_2; ?>[] " ?
Are you doing a multiple insert with it already?
Kumel
yes it is.
In that case you would probably have to do it by hand. Loop through the post and create an array of the UserIDs and then use that to filter a recordset. I could help with something like that in a premium support ticket. Another option might be to create a recordset that gets the results of the newly inserted records and use that to send the email.
Kumel
i will try to figure something out.
