Date picker showing up in unusual place.
Thread begun 5/04/2016 1:31 pm by BillHobbs | Last modified 5/05/2016 2:22 pm by Ray Borduin | 2859 views | 6 replies |
BillHobbs
I've been using Datepicker but when I view it in various browsers the calendar pops up away from the actual date field if it shows up at all. Is there a way to force it to be beside the date field? I've uploaded a screen capture of what is happening. I also sent the file in question.
Thanks.
It should always appear by the field... What browser is this an issue on? Can I get a url to see the problem live? That might allow me to better understand the cause. Perhaps it is conflicting CSS in your site.
BillHobbs
http://www.barkingshark.info/request-appointment.html I seem to have the problem in Safari and Chrome. If Firefox the calendar pop up shows up above the field. I have a similar problem when using HTML Editor. In HTML Editor the styles pull down does the same thing.
Can I get FTP access? I see what you are seeing, but need to try some things to debug.
BillHobbs
Here are the details.
The issue was the position:absolute; css attribute you had put on the body tag in the main.css file. I removed that and it appears to have fixed the problem.
BillHobbs
Thanks, that seemed to do the trick.
