http://www.hemogenix.com/CMS/admin_cms/users_login.php?failed=1&
Thread begun 5/03/2016 10:53 am by gzirfas374932 | Last modified 5/04/2016 11:19 am by Ray Borduin | 2602 views | 4 replies |
gzirfas374932
I have not changed any code on this site for quite some time. I checked with the server and no php updates or anything have been done. I tried turning on error codes <?php error_reporting(E_ALL); ?> but then everything stops working. I will probably need your help to find and correct this problem. I CAN log in with the supper admin credentials but doing anything, like edit users or editing the content simply returns to the index page. Can you let me know what I need to do to help me get this corrected?
If you send me FTP access I can try to debug the issue.
gzirfas374932
requested info
credentials in PM
The session start code wasn't working properly... probably an upgraded version of php and older version of the PowerCMS causing conflicts.
I fixed the problem by updating the WA_SecurityAssist/Helper_PHP.php file.
gzirfas374932
Saved my keester again, everything works great.
I downloaded the files to my local machine to make sure they were identical to the server. You saved my keester AGAIN. Your software I consider as one of my BEST investments and I have recommended it to my colleagues frequently. Your support is UNSURPASSED. Thanks again for everything you do.
