Does the Server Behavior work for Mac Dreamweaver 2015?
Thread began 5/03/2016 7:28 am by Melina | Last modified 5/06/2016 6:53 pm by Ray Borduin | 1555 views | 7 replies |
Melina
I have purchased the server behavior extension (MySQLi104.zxp), downloaded the Deprecated ServerBehaviorsPanel Support and installed them using the DMXZone extension manager. However, Server Behaviors is not showing in my Windows menu. Under the WebAssist menu, all I see is Database > Model Database. That window only shows my tables, but no way to construct the query.
Do I have the wrong version? Am I wasting my time?
It sounds like the Deprecated Server Behaviors extension didn't get installed properly. Did you install it using the DMXZone extension manager? It definitely works with Mac Dreamweaver 2015. I use it on that platform.
Melina
I did install Deprecated_ServerBehaviorsPanel_Support.zxp using their extension manager. In fact, today, I removed and reinstalled, with the same result.
Is it possible that I installed an incorrect version? the date modified on the one I downloaded (from a link on this board) is Feb 19 2014. Is there a newer one, possibly?
It won't be under the main menu. Open the Server Behaviors panel in Dreamweaver and click the plus button there. Choose 'WebAssist-> MySQLi-> MySQLi Recordset' to add a result set to your page.
Melina
Unfortunately, my problem is that the Server Behaviors panel is not showing up. I've attached a small screen grab of what shows up under the WebAssist menu. Model Database is all that's there.
If the Server Behaviors menu doesn't show up then the Deprecated Server Behaviors extension didn't get installed properly. That is necessary to get working first before our extensions will work.
Melina
I've attempted to get that installed, but I have had no success. I'm down to hand typing the code, and if I'm going to do that this was not a good use of money. What is the process for accessing the money back guarantee?
Just email sales@webassist.com with a copy of your receipt. If you want help installing just post your phone number and I'll call you and set up a screen sharing session to help make sure it gets installed and works properly.
