Datepicker not working
Thread begun 4/25/2016 9:37 am by Mags | Last modified 4/26/2016 11:39 am by Ray Borduin | 4001 views | 6 replies |
Mags
Just added a datepicker to a field on a new page on a site which already has working datepickers, but this one isn't working - nothing happens when I click in the field. I've checked for conflicting versions of jquery but all seems to be OK. Could you take a look? It should be on the Expected Start Date field.
http://www.accountant-registration.co.uk/LifeAssurance/rate-calculator.php
These two lines are out of order:
<script src="../js/bootstrap.js"></script>
<script type='text/javascript' src='js/jquery.min.js'></script>
should be:
Mags
Tried that but still not working.
CraigRBeta Tester
According to the console, you have an error
Uncaught Error: Bootstrap's JavaScript requires jQuery version 1.9.1 or higher
you are using 1.7.1
Mags
Tried changing to the most recent jQuery, still no joy. As I said, I have other working datapickers on this site which use older versions of jQuery & Bootstrap, but for some reason I just can't get this one to work. I've even tried stripping out Bootstrap JS & CSS files, still nothing. I'm still getting an error in the console, rate-calculator.php:34 Uncaught TypeError: $(...).datepicker is not a function but I don't know enough about Javascript to fix this (and line 34 is the standard Webassist datepicker script that works on all other pages anyway). Never had this issue before, it's driving me nuts!
You are still getting an error in your jquery include. Try using the google hosted version.
Replace:
<script src="//code.jquery.com/jquery-1.10.2.js"></script>
With:
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.12.2/jquery.min.js"></script>
Mags
OK, I've narrowed down the section of code that's causing the error - the calculations in the form were generated by SpreadsheetConverter and there's a big chunk of script after the closing <body> tag, which contains something that's conflicting with the datepicker. If I remove all of that code, the datepicker works but then of course the calculation doesn't! I'll raise a support ticket with SpreadsheetConverter to see if they can advise!
