Best Method - check if all fields in a Record are not null or empty
Thread begun 4/23/2016 1:56 pm by Steve | Last modified 4/25/2016 10:44 am by Ray Borduin | 1707 views | 3 replies |
Steve
I have a record from a MySQL Database that needs to be validated to see if all the fields have any value or return some alert.
Is the best way to put all the field values into an array and then check the SUM where IS NOT NULL or Empty to see if it matches the qty of selected fields?
EXAMPLE: $result = | Value | NULL | NULL | Value | EMPTY |
In this example the Record has values from 5 Fields and 2 of those Fields are not Null or Empty
I need Validate to see when all 5 Fields have some value.
So it is a specific Record not the whole RecordSet and the goal is to see if all the fields have a value Or do Something.
CraigRBeta Tester
Are you familiar with the mysql LEAST function ?
eg SELECT LEAST (Field1, Field2, Field3, Field4) AS AnyNull FROM tblname
If any argument is NULL, the result is NULL.
http://dev.mysql.com/doc/refman/5.7/en/comparison-operators.html#function_in
Steve
Thanks CraigR
Yes, but I used the GREATEST function to solve the problem:
SELECT *
FROM table1
WHERE GREATEST(col1, col2, col3, col4) IS NOT NULL
<?php if($recordset->TotalRows != 0) echo ' (<span class="red">All necessary Reqmts in place</span>)'; ?>
GREATEST() returns NULL if any argument is NULL.
CraigRBeta Tester
Glad you got it sorted.
Either way should work. I am pretty sure LEAST returns null if any value is null too.
