Dynamic select list not populating from database
Thread begun 4/20/2016 11:44 am by tmcbinc99963 | Last modified 4/29/2016 9:10 am by Ray Borduin | 3357 views | 8 replies |
tmcbinc99963
I'm adding a dynamic select list to an existing search results form, allowing the customer to select a product size from the results, then submit to an eCart checkout page.
First, the select list won't populate the product sizes from the recordset.
Second, the select list has created a search result that shows only the first entry from the database multiple times. When the select list is deleted, the results display correctly.
You are trying to populate the select list from the same recordset you are displaying the results from... usually you would create a second recordset to populate the select list and nest that recordset inside the repeated region so that each row would have it's own results.
tmcbinc99963
A separate recordset has been created, along with a repeat rows behavior.
I'm using the Property Inspector 'bind to dynamic source' panel to populate the select list. The menu shows every record in the Db, rather than only those associated with the product.
You need to move the recordset code from lines 116-120 down inside the repeated region after what is currently line 551 so that it is recreated for each product.
Then you need to filter the recordset using the productID so that it only shows records for the current row. To do that, filter the recordset using a URL parameter ProductID and then add this row above the recordset:
$_GET['ProductID'] = $row_WADAProd['ProductID'];
tmcbinc99963
When the recordset code is moved inside the repeating region, I get the following error:
Notice: Undefined variable: ProdSizeSelectList in /Applications/MAMP/htdocs/primrose.com/Prod_results.php on line 678
Warning: mysql_free_result() expects parameter 1 to be resource, null given in /Applications/MAMP/htdocs/primrose.com/Prod_results.php on line 678.
Also, when trying to filter the advanced INNER JOIN recordset, I copied an earlier simple recordset that was filtered using the URL Parameter and ID, then clicked advanced, and added the INNER JOIN text back in. I keep getting a syntax error in the WHERE clause on the colname variable default value. I've tried -1, 1 and ID, but still get the error.
File and recordset image attached.
You moved it into the wrong repeat region... it should be just after line 546.
I don't see the where clause or parameter in the recordset at all, so I can't comment on what was wrong with it in your tests... but it sounds like you may not have typed in the correct parameter name to match the placeholder in the SQL when you added it.
tmcbinc99963
It still gives me the same error message after moving the code, and multiple records don't show up in the select list. It also doesn't show the appropriate sizes for each product.
SELECT *
FROM Prod INNER JOIN ProdType ON ProdType.TypeID = Prod.ProdType INNER JOIN ProdSize ON Prod.ID = ProdSize.ProdSizeID INNER JOIN ContSize ON ProdSize.ContSizeID = ContSize.ContID
WHERE ID = colname
GROUP BY ID
colname type: integer
default value: -1
run-time value: $_GET['ID']
File attached.
This looks correctly placed. What is the current error that you get on the page?
If you test that SQL statement in PHP MyAdmin do you get the results you expect (replacing the parameter with a valid ID from the products table of course)?
tmcbinc99963
The error was in the SQL statement. The product size table wasn't properly configured to pick up the URL.
Thanks for your help.
