Not able to get value from session
Thread begun 4/17/2016 12:15 pm by rogersds267040 | Last modified 4/26/2016 11:39 am by Ray Borduin | 5466 views | 21 replies |
rogersds267040
I'm trying to get session value but not able to. Even thought he values are in session when they are printed as seen below.
Tried using <?php echo $_SESSION['Renter_Age']; ?> to get the session value but it's blank.
Array
[WASF_IndexBooking_HomeBooking_HomeBooking] => Array
[Pickup_Location] => UVF
[Pickup_Date] => 04/18/2016
[Pickup_Time] => 8:00 AM
[Return_Date] => 04/18/2016
[Return_Time] => 10:00 AM
[Renter_Age] => 25+
[IndexBooking_submit] => Submit
[PHPSESSID] => p01j2iprtb3k64t8f945nbhsg1
Dave BuchholzBeta Tester
try
<?php echo $_SESSION['WASF_IndexBooking_HomeBooking_HomeBooking']['Renter_Age']; ?>
rogersds267040
Thank you Dave.
I have a quick questions. I'm a newbie in php.
How can I update a session value using another form? I'm creating a car rental site.
Lets say someone enters pickup date and time on the first page and went to a summary. Then they decide to change the pickup date and it's in session. How could I change the session value?
Any assistance will be appreciated.
You can set the value just like you would any other variable:
$_SESSION['WASF_IndexBooking_HomeBooking_HomeBooking']['Renter_Age'] = "22";
rogersds267040
Thank you very much Ray.
The reason I asked the question is because I have a page which looks fine but the session is not getting updated from the form.
I have attached the page.
What exactly are you trying to save and where? The action of this form is set to booknow.php, which means any code saving sessions from the form would have to be on that page.
rogersds267040
Updating session values
Hello Ray,
Just to give you a little background of what I'm trying to accomplish. I'm creating a car rental website. (http://www.hsautorental.com/index.php)
On the first page (http://www.hsautorental.com/index.php) a user can start reserving a vehicle. The first page I collect Pickup location, Pickup date, pickup time, return date, return time, and renter age. All this information go into session when submitted.
On the next page, the user selects a vehicle and navigates to the summary page. On the summary page (bookNow.php) the user can modify the session values by clicking the MODIFY link next to the variable. They will be navigated to update.php page where they can make the update which supposed to be in session. By selecting the correct values in the form, on submit, it supposed to update the session values and take you back to the bookNow page.
What I'm noticing, from the bookNow.php page, the values for the date and time are not defaulting in the form on the update.php page.
Also, on submit, the session values are not being updated.
Any assistance you can provide will be appreciated.
You would have to add the code to update the session on teh bookNow.php page (the action page of the form) any code reacting to the form post has to be on the action page... that page has no code to update the session currently, which is why it isn't updated.
rogersds267040
Thank you Ray.
I will try this option.
How can I default the Date and Time from session to the update.php page form?
It should work just like any other field.... it looks like you are referring to the session as: "IndexBooking_NewFromBlank_Default" but earlier I see the session saved is: "IndexBooking_HomeBooking_HomeBooking"
Try doing a find and replace to use the correct session reference.
