403 Forbidden Error when submitting update page
Thread begun 4/15/2016 10:58 am by Justin@AdventDesign | Last modified 4/20/2016 1:13 pm by Ray Borduin | 1274 views | 3 replies |
Justin@AdventDesign
I'm stumped and could use some direction. This site is several years old and this update page has worked fine in the past. All of the sudden, I get a 403 Forbidden Error upon submission of the form. I did add a field recently, so I tried reverting to the previous version of the page to see if my changes entered an error, but the previous version gives the same error. A few other things tried:
- The page is located within a password protected directory. I removed the password protection temporarily to see if that was causing an issue. No dice.
- Permissions for that folder are set to 755. I temporarily set to 777. Still no dice.
- I have numerous other "update" pages that were generated at the same time this page was and they still work without error.
I've attached the page, but I'm at a loss as how to trouble shoot further. Any direction would be appreciated.
Justin@AdventDesign
Ray? Anyone have any thoughts here?
It could be a security module installed preventing html code from being posted... I see you are using an html editor and sometimes security is added to a site to prevent html injection that basically prevents html editors from working. I'd ask your hosting provider to see if that is what is going on.
A good test would be to make the editor field blank when submitting and see if the error goes away. That would be a sign that the html in the post is causing the error.
Justin@AdventDesign
So I did some more testing to see if I could further isolate it. First, on your suggestion:
- Removing everything from the HTML editor field gives the same error
- On the insert page, uploading HTML via the editor field works without incident
- I noted the record they were trying to edit when they first reported the error has external links in the HTML field, so I removed those, same error
- We also have field with an email address, tried dropping that, same error
- We also have a field with a map embed using iframe. Tried dropping that, same error
HOWEVER, we have fields for social media links and whenever we have the URL string that contains "HTTP://" or "HTTPS://" in one of those fields it throws the error. If we don't have that in, it updates fine.
I'm following up with the host.
