trouble setting up PowerStore
Thread begun 9/03/2009 10:40 am by barbara224891 | Last modified 9/16/2009 1:43 pm by barbara224891 | 9356 views | 17 replies |
barbara224891
Hi, I'm trying to use PowerStore for the first time. I can't seem to get my globals set right to let the admin user log in. I'm happy to pay for a support incident to get a little hand-holding, but I can't find where on the site to request one. I left a message on the support line.
The username and the password for the admin is controlled in the globals file with these tow variables:
$WAGLOBAL_Admin_UserName = "" ;
$WAGLOBAL_Admin_Password = "" ;
As a simple test you can just put in the word test into both of these, then save the page and make sure it is uploaded to the live site where you are testing this. When you browse to your powerstore files you will go into the admin folder like this:
yourPowerStoreFiles/Admin/
If you are not able to successfully login please explain what is occurring when you try.
barbara224891
nothing happens
When I go to the page index.php
and submit the username and password of test, the page resets with this as the url:
index.php?failed=1
How have you set the $WAGLOBAL_Admin_UserName and $WAGLOBAL_Admin_Password in the WA_Globals.php file? to test as the Username and password, you need to set it like:
$WAGLOBAL_Admin_UserName = "test" ;
$WAGLOBAL_Admin_Password = "test" ;
If you still have a problem, try deleting the WA_Globals.php file from the server then re uploading to make sure your changes are going up to the server.
barbara224891
I did set them equal to test in the globals file. I tried deleting it from the server and then putting it again. Still the same problem.
barbara224891
could the remote root be a problem?
Please help! It's been over a week that I'm stuck on this. I'm willing to pay for a technical support incident if I can just get this problem resolved...
I'm wondering if I have the remote root set correctly. I set it using the same path as I use on the folder for my Dreamweaver configuration. Does that seem right?
warrenphillips25336771Beta Tester
Originally Said By: barbara224891
Barbara
Drop us the code for what you have n the admin part, it will only be a small fault.
Originally Said By: warrenphillips25336771
  Barbara
I mean let us know what you have put into the fields, I have mine all setup and working correctly. If you want a hand just ask, I don't work for these guys but will help
barbara224891
$WAGLOBAL_Root_URL = "http://ElizabethLynne.com/" ;
$WAGLOBAL_Site_Name = "Elizabeth Lynne" ;
$WAGLOBAL_Address = "8899 University Center Ln Suite 330";
$WAGLOBAL_City = "San Diego";
$WAGLOBAL_State = "CA";
$WAGLOBAL_Zip = "92122";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "ABQIAAAAXafbUiGiRYj0bogExLhVCRT2yXp_ZAY8_ufC3CFXhHIE1NvwkxT5czkOfeMRZCjwJ7_QG4gFmJ1OGQ";
$WAGLOBAL_localRoot = "/";
$WAGLOBAL_remoteRoot = "/www/elizabethlynne.com/";
// Admin Settings
Here's the stuff from the globals file. I assume that's what you're asking?
The remote root should be set as:
$WAGLOBAL_remoteRoot = "/";
it is the root of your site, and only needs to be set if the files are in a sub directory such as:
powerstore/
Everything else looks correct, can you send the following file so I can look into this one:
HelperGroupsRulesPHP.php
