themes/temp_editing/css/configurable.css
Thread begun 4/01/2016 12:29 pm by mrobben375515 | Last modified 4/04/2016 3:20 pm by Ray Borduin | 3352 views | 4 replies |
mrobben375515
I have PowerStore 4.5. I am trying to use store/admin/design.php inside the admin to edit my site. When I click any of the templates to edit them, I get the following errors: The site and credentials are attached privately.
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 87
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 88
Warning: fread() expects parameter 1 to be resource, boolean given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 88
Warning: fclose() expects parameter 1 to be resource, boolean given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 89
Warning: get_object_vars() expects parameter 1 to be object, null given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 94
Warning: get_object_vars() expects parameter 1 to be object, null given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 95
Warning: get_object_vars() expects parameter 1 to be object, null given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 96
Warning: get_object_vars() expects parameter 1 to be object, null given in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 97
Fatal error: Call to a member function asXML() on a non-object in /home/content/05/11651305/html/marketing1to1/store/webassist/plugins/styler/styler.php on line 105
Delete the: webassist/themes/temp_editing folder and all of its contents. It appears it didn't get created or deleted properly at some point but manually removing it should cause it to reset.
mrobben375515
Thank Ray. I did this but same result. I noticed that the "styler.php" file was being called from /store/webassist/plugins/styler/styler.php but that file was actually only inside /store/install/webassist/plugins/styler/styler.php Actually, there was not any webassist folder in store/, only in store/install/ so I copied it and placed it inside store/ All that said, I still am getting the same error.
I went to the site and it appears to be working now. Let me know if you are still having issues I may have missed.
mrobben375515
yes Ray, I reinstalled all the PS 4.5 files and it is working now.
