Extension Order
I wonder if my extension order is correct, I attach a picture.
When installing which should be installed first, second etc
John
John
I see from anaother thread the extension order does not matter any more.
That is correct... since we consolidated into four products we are able to keep them in sync and install order is no longer significant as long as you have the latest versions.
If you ever had an older version of one product, then you would want that installed first, but it looks like you are all up to date.
