Checkout.php Remove Required Validation
Thread begun 3/30/2016 11:22 am by jon392819 | Last modified 3/31/2016 10:15 am by Ray Borduin | 1559 views | 3 replies |
jon392819
Hi, checkout.php I need to make the Post / Zip code optional and also change the phone number validation to allow more than 9 digits. Tried and failed on both counts.
Removing validation on the post code results in the form failing to post to PayPal.
Any help appreciated
Jon
Did you remove both the client and server validation? Do you get a paypal failure, or does it simply not get there because the server validation hasn't been removed.
I'd need to take a look at your checkout.php and confirm_cart.php pages to see what you might be missing.
jon392819
Thanks Ray, I only removed server behaviors on checkout.php. I did not look at confirm_cart.php
I can look at this file also. Is it easy to increase the allowed number of characters in teh phone field?
Jon
Yes. There is an option in the server behavior to allow international, and that will allow more characters.
