Calculate a price
Thread begun 3/30/2016 8:36 am by mrobben375515 | Last modified 3/31/2016 11:15 am by Ray Borduin | 2099 views | 4 replies |
mrobben375515
Calculate a price
I need to display in the shopping cart what the approximate exchange rate value of the cart is in Canadian dollars. I added a record to wa_settings called "Ca_Ex_Rate" with the value being the rate for the day. I want to multiply the cart's grand total by the value in wa_settings. The php line I have below is returning $0.00. How can I fix this to display the correct value?
<?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->GrandTotal()) * $row_Ca_Ex_rate['value']; ?>)
I think it should be:
<?php echo WA_eCart_DisplayMoney($eCart1$eCart1->GrandTotal()) * $GLOBALS['WAGLOBAL_Ca_Ex_Rate']; ?>)
where "Ca_Ex_Rate" is the value of the 'variable' column in the wa_settings table.
mrobben375515
Ray, I made the edit but still getting zero for the value. I did this same code for product_details.php and it seems to work. I am attaching the cart_test.php page I am working on, a screen shot of where the value show show and credentials to the site should you need access.
Since you aren't using a powerstore theme for your design, the GLOBAL variables aren't automatically defined.
I added code to the page on lines 4-26 so they are available on the page.
Then it appears you don't have a value for the 'variable' column in the wa_settings table for that row, so I had to change the reference to:
$GLOBALS['WAGLOBAL_']
Normally the variable name would appear after the underscore. It appears to be working now.
mrobben375515
Yes, it is working fine. Thank you for the note and fix!
