sorting columns
Thread begun 3/29/2016 1:35 pm by Jamie | Last modified 4/04/2016 11:04 am by Ray Borduin | 3206 views | 8 replies |
Jamie
sorting columns
Hey Ray
In the attached page I have set a sort on each of the columns - this works fine.
Where it 'falls down' is if you set a sort, for example by price, then the pagination navigation (which is set to 25 recordsw) when clicked doesnt show the next logical set of 25 results but jumps around.....
Not sure what I need to do to achieve this
Also on the same page, in the search area, how does one make it so that when you hit enter on the keyboard the 'search' button is used?
Cheers
Jamie
Can I get a url to reproduce? It is probably keeping the sorting parameter in the url which resets the sort. The solution is probably to check for the sorting url parameter on or around like 192-193 and omit it from the navigation url just like the two parameters already listed on those lines are.
Jamie
Thanks Ray. See PM
odd... it seems to be working for me.
1) I go to the product page
2) I click on price
3) hit the next button
4) it shows the next logical set by price.
Am I missing a step?
Jamie
Hmmm not sure but when I do the same the next page starts with a product with a price of 89. If I click on next again (so page 3 of the results) it then shows the top result as 5.99. Page 4 then jumps up and so on.....
Try updating lines 192 & 193 from:
if (stristr($param, "pageNum_WADAproducts") == false &&
stristr($param, "totalRows_WADAproducts") == false) {
stristr($param, "sort") == false &&
Jamie
perfect....thanks. so what is that doing?
It removes the "sort" parameter from the navigation url... that was reversing the sort with each press of the navigation button.
I think the return button automatically presses the first button in the form. If you switch the order of the two buttons and use style="display:inline-block;float:none;" to position them you should be able to get it to work automatically.
Jamie
thanks Ray. have rejigged it along those lines and working great
Cheers
Jamie
