Navigation for Wordpress and PowerStore
Thread begun 3/29/2016 1:22 pm by thinkdolphin | Last modified 3/30/2016 2:09 pm by Ray Borduin | 1501 views | 3 replies |
thinkdolphin
I have Wordpress and Powerstore on the site. How do I tie the navigation into both?
You can just add links to the menus to navigate from one section of your site to another.
thinkdolphin
I know how to change the link on the Powerstore side. I'm not sure how to add the navigation for Wordpress. Only one page right now is Wordpress. I'm not sure if I should copy the code from the menu.php file or just put the HTML in from the source.
That is going to depend on your wordpress theme. You might have difficulty copying in the entire navigation because of the database references. It might make sense to have a simplified navigation on the wordpress page that gets you back to the most common areas of the main site and they can use the full navigation after they return.
