oppinion on admin approach on ecommerce website
Thread begun 3/28/2016 5:15 pm by Christopher West | Last modified 3/29/2016 9:48 am by Ray Borduin | 1938 views | 3 replies |
Hi, I am trying to design a good approach for my new ecommerce website.
(1) Currently I have a supplier uploading product images via FTP to the server, they are also including a .CSV which I intend to set up a CRON job so it adds the data to a table on the database. With this I have setup on the backend to allow my client to select from these records and create a product. With this approach I am not storing any product filenames directly in the products table in the database. The filenames of the product images consist of the product SKU (which is stored in the product table - I could also allow the client to manually upload a product image if required. This approach does mean that I cannot use any WebAssist server behaviors to do any image manipulation such as image resize. But can use the WebAssist server behavior to cache a resized image on the server. Any thoughts on this approach. Am I missing any potential problems that could arise?
(2) Relating to the above, I may have discovered a bug, In the backend part of the website, when I initially look at the page displaying all the newly uploaded images (there are over 1000). Using the pagination last page button, The very last record that was showing was a PHP error relating to the WebAssist Image Resizer server behavior. I need to reproduce this, but is there a limit on what the server behavior can do since it is caching a lot of images?
(3) Im trying to plan ahead and figure out a good way to allow my client to assign products to categories. basically I have 3 tables (category, product and a linking table which stores the ID values of both the category and product records). My questions are; (a) Should I design it so that when the client goes to the category section in the admin, they can click a link beside each category record which takes them to a page where they can chose a product to assign...or (b) when the client goes to the product section in the admin, they can click a link besides each product record which takes them to a page where they can chose a category to assign? (c) Do I do both approaches from questions A and B? (d) I was thinking on the actual product update page I could create a dropdown where client can chose a category to assign, when they have chosen one, I can use javascript to display another dropdown where client can chose another category to assign and so on) - This could be a different form submit on the page). is there an approach I haven't thought of?
Chris
Missing images can cause errors... that was probably what was going on. You can wrap the image tag with an IF statement to make sure it isn't displayed when the image doesn't exist. Resizer is a good approach otherwise.
I think either approach on the category assignment would be acceptable. It is a usability decision probably based on the number of items you might have in a category. If there are going to be a lot, then maybe selecting products for the category would become hard to manage, but if there will only be a few dozen products, then that might be the easier approach.
Thanks Ray, Yeah there are missing images on the server, So that's cleared that up :)
Yeah I need to nail the approach soon as I need to code it :) I would like to have the mind set that there is going to be a lot of products (just because I will cover myself in case the client comes back, I like the idea of using javascript to display a select list each time the clients assigns a product to a category or vice versa (depending on the approach) I have never used multi select on a select list where it updates the database (perhaps you can help me on that on a premiere support ticket). Obviously I need to allow the client to remove product <-> category associations as well. would a multi select list approach be better than displaying an individual select list each time? I assume the mutli select list approach will be harder to code? Well its beyond my scope :)
Chris
Multi-select list would be easier to code. Repeating select lists with javascript is more difficult, but we could do either in a support ticket.
