Best validation for MySQLi insert completed ?
Thread begun 3/28/2016 12:25 pm by Steve | Last modified 3/29/2016 2:00 pm by Ray Borduin | 5453 views | 11 replies |
Steve
Hello,
We have a form that is suffering from validations NOT catching various inputs people are entering.
No errors stop the page from moving to $WA_redirectURL
I'm surprised the MySQL DB does not throw an error but it seems not to be the case.
One of the prior found errors was a vachar field that was 14 characters in size but the person entered 15 characters. This caused the record not to be submitted but there was no error that stopped the page from moving to it's $WA_redirectURL location.
Is there a value we should poll before moving to the redirect page?
I understand we should have page level validation and we do, but since we don't get these errors stopping the flow it's hard to track down where problems exist.
I believe it should stop the page and throw an error. In the case of too many characters I think it should insert, but just the first 14 characters would be saved. If you have a url and steps to reproduce the problem I can debug it and see why it isn't behaving the way I would expect it to in your case.
Steve
I agree, the input should have been truncated and errors should show when encountered. Not sure why this is not happening.
Which field has the length limitation that I can use to reproduce the error?
Steve
That's the problem.. As we find a condition that prohibits an Insert but without error, we fix it such as adding a limitation on the input field for the 14/15 character problem.
Last case we believe was known was the List Relatives/ friends and How Referred text areas. We boosted those to 256 so probably a 'greater than' would reveal the problem but I have not confirmed. I can test further tomorrow.
Steve
Hello, I have removed the input max-size from one of the fields that was identified as causing an issue before. Try 15 characters and it should fail in silence... Database fields info in attached images.
<div class="col-md-6"> First Available Start Date:
<input name="FirstAvailDate" type="text" id="FirstAvailDate" placeholder="mm/dd/yy" size="8" >
 </div>
I can't seem to actually upload files with the ftp credentials you supplied. I'll need to edit the code to fully debug.
Steve
Ack! Sorry Ray... I've changed the permissions.
I've updated your webassist/mysqli/queryobj.php file to the latest unreleased beta version which has additional debugging information.
You can turn off debug mode in that file and it will still stop the page from processing but not include as much details about the failure (recommended when going live to prevent would be hackers from knowing more information about your database than they should like table and column names).
Steve
Ray, so we now see when there is a conflict on INSERT? And the page will not proceed like it did prior?
Is there a way to interpret the errors in such a way that they could be made into a user-friendly alert to help the Applicant see where a problem may exist in their submission?
