Data Assist pages not created
Thread begun 3/27/2016 12:26 pm by john70964 | Last modified 4/05/2016 11:29 am by Ray Borduin | 4692 views | 13 replies |
john70964
I seem to be having problems with the extension for Data Assist pages
I think I am following the correct routine but when running the create routine I get the error attached in the image below.
I deleted the old configuration file and a new one was created.
I have DW CS6
Any ideas please?
Thank you
John
john70964
I think I found the answer to my question.
I had created files for results and Details.
Then when a page was created I navigated to where I had created the files and selected the correct file.
The file name only showed in the Page and Location Box.
Details.php
Later I did not create the empty files but navigated and named the files in the Page Name and Location box.
Then the correct full path then showed in the Page and Location Box, not just the file name
myfolder/Details.php
This seems to have solved the problem
Regards
John
john70964
Previously I was able to create pages with the Data Assist wizard. Now I seem once again to be unable to create a results and details page in Data Assist. I have renewed the config file.
For Instance I create a Results Page and the name Boats_results.php appears in the Page Name and location box. As the location does not appear I click the folder button which takes me to the folder I started with.
So now in the folder where I started, I type in the name of the file in the File name box boat_results.php and I notice a box marked URL also displays boat_results.php
I select OK and the page Name and Location also shows boat_results.php not
my folder/boat_results.php
I did try typing the path in the box but when I look at myfolder/ boat_results.php or boat_details.php these files are not listed.
On the last occasion I noticed that the creation process stopped at Apply Recordset
Can you please advise me where I maybe going wrong.
Many Thanks
John
PS a slightly new error message arrives
Please post a US phone number or Skype contact information and I'll set up a screen sharing session to look into this one with you. I'm not familiar with that error, so I'll have to debug it directly.
john70964
Thanks Ray
I will come back to you I hope tomorrow but it could be later.
Regards
John
OK, just let me know when by replying here and I'll set up a meeting to look into it.
john70964
Please see PM
john70964
Hi Ray
I updated all of the extensions and now get a different error which I have attached.
Still the results and detail pages do not get created.
Regards
John
Try clearing the filecache.dat file from the users configuration folder.
john70964
I have cleared the configuration file several times but still come up with errors. The latest error message is attached.
I find that recordsets seem to disappear after creation of new results pages.
Because of the errors results/detail pages are not often completed, sometimes they are but mostly not.
I wondered if Dreamweaver had become unstable and whether I should update/reinstall Dreamweaver?
I downloaded AdobeDreamweaver-12-0-All-Update_upd.zip but thought I should ask your opinion before going ahead.
Many thanks
John
