Pagination and Search problem
Thread begun 3/26/2016 2:18 am by jimsg4 | Last modified 3/28/2016 4:30 pm by Ray Borduin | 2463 views | 5 replies |
jimsg4
I have an issue where I have a Keyword DB search that works great unless I use pagination for my records view. The results loads on the same page, page zero (index.php). If I start a search on page 0 everything is fine. If I start a search on any other page I get blank results (1 row) until I page back to page 0 where the results finally show up.
Thanks,
Can I get a copy of the page you are working on? I'll be able to suggest a fix.
jimsg4
See attached
My page is attached. Everything works great except for the search from a page other than zero.
Thank You!
I think if you add action="index.php" to the form on line 294 and it should fix that problem.
jimsg4
Hi Ray. Unfortunately it had no affect. It does the exact same thing.
jimsg4
It worked
Hi Ray, Please disregard my sensless last message. your answer did work. Funny how a 2nd pair of eyes and experience can help solve a problem. Thank you for your help Ray!
