DataAssist Search 'contains' not 'exact match'
Thread begun 3/25/2016 9:33 am by gb261593 | Last modified 3/28/2016 5:21 pm by Ray Borduin | 4210 views | 8 replies |
gb261593
I have an old version of DataAssist which generally works fine. I want to carry out a check through a database 'clients' which contains (amongst other things) forename, surname and postcode.
I want to design a search where there are 2 input fields 'name' and 'postcode' and where the system checks if the forename contains the name input, or the surname contains the name input or the postcode contains the postcode input.
I have it working so it check if the surname is an exact match or the postcode is an exact match but am not sure how do do what I want. Is it possible?
Yes... in the search code you just have to change "=" to "Includes"... If you have difficulty finding where, send me a copy of the results page I can reference line numbers.
gb261593
Thank you. I tried that but it didn't seem to work so I have included the code below. I just changed two '=' signs as you can see. Any guidance would be very welcome.
Also, this example only checks if the surname field matches the surname input field. Because some names are put the other way round I wanted to check the forename field against the surname input as well. Is that possible?
The code is:
//WA Database Search Include
require_once("../../WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rsList;
//Searchpage: conflict_check.php;
//Form: form1;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromEdit("surname","surname","AND","includes",0);
$WADbSearch1->addComparisonFromEdit("postcode","postcode","OR","includes",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_conflict_check_results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_conflict_check_results"]) && $_SESSION["WADbSearch1_conflict_check_results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_conflict_check_results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
// Load the tNG classes
require_once('../../includes/tng/tNG.inc.php');
// Make unified connection variable
$conn_blac = new KT_connection($blac, $database_blac);
//Start Restrict Access To Page
$restrict = new tNG_RestrictAccess($conn_blac, "../../");
//Grand Levels: Level
$restrict->addLevel("9");
$restrict->Execute();
//End Restrict Access To Page
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_blac, $blac);
$query_rsList = "SELECT clientid, forename, surname, add1, add2, add3, town, postcode FROM client ORDER BY surname ASC";
setQueryBuilderSource($query_rsList,$WADbSearch1,false);
$rsList = mysql_query($query_rsList, $blac) or die(mysql_error());
$row_rsList = mysql_fetch_assoc($rsList);
$totalRows_rsList = mysql_num_rows($rsList);
<table border="1">
<tr>
<td>clientid</td>
<td>forename</td>
<td>surname</td>
<td>add1</td>
<td>add2</td>
<td>add3</td>
<td>town</td>
<td>postcode</td>
</tr>
<?php do { ?>
<tr>
<td><?php echo $row_rsList['clientid']; ?></td>
<td><?php echo $row_rsList['forename']; ?></td>
<td><?php echo $row_rsList['surname']; ?></td>
<td><?php echo $row_rsList['add1']; ?></td>
<td><?php echo $row_rsList['add2']; ?></td>
<td><?php echo $row_rsList['add3']; ?></td>
<td><?php echo $row_rsList['town']; ?></td>
<td><?php echo $row_rsList['postcode']; ?></td>
</tr>
<?php } while ($row_rsList = mysql_fetch_assoc($rsList)); ?>
</table>
Try using "Includes" with a capitol "I"... data assist is a little particular with that.
gb261593
Many thanks - that works fine now. Also:
This example only checks if the surname field matches the surname input field. Because some names are entered by users the other way round I wanted to check the forename field against the surname input as well. Is that possible?
Yes... open up the DataAssist Search server behavior and change the search type to "Keyword"... that will allow you to multi-select more than one column in the table to search against.
gb261593
Thank you but I can't find where to do this. Is it because I use an old version ie DataAssist 2.1? If not, do I do it when I first set up the search or by editing afterwards.
The results page should have the Search server behavior listed in the server behaviors panel.
To do it manually replace this code:
with this:
$KeyArr1 = array("forename", "surname");
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["surname"]))?$_POST["surname"]:"")  ."","AND","Includes",",%20","%20","%22","%22",0);
gb261593
That works perfectly - very many thanks for all of your help and being so patient.
