Form Builder Parse Error
Thread begun 9/03/2009 4:50 am by mark.hay302689 | Last modified 9/08/2009 1:45 pm by Jason Byrnes | 6659 views | 6 replies |
mark.hay302689
I've just got hold of Form Builder and immediately hit a problem. If I build a page vanilla or with template and just use the inbuilt forms e.g. registration simple or rich and simply finish there and then when I test it I get a parse error on line 12 - Checking the code line 11 is
WAValidateEM((isset($_POST["Registration_group_Email_address"])?$_POST["Registration_group_Email_address"]:"") . "",true,1)
line 12
WAValidateRQ((isset($_POST["Registration_group_Password"])?$_POST["Registration_group_Password"]:"") . "",true,2)
and so one dependant on the number of validations - I can spot that the ';' is missing from the end of the line and inserting it will fix the problem. But why is it missing in the generated code?
I can repeat this problem over and over. Anyone else having a problem or is this something local to my system?
I'm not able to reproduce the problem using Dreamweaver CS4 on Windows Vista.
What Dreamweaver Version and OS are you using so I can try reproducing the issue ion a similar set up.
mark.hay302689
Same as yourself
mark.hay302689
Plain File
I've attached a plain simple form using no more than the login choice form option -
here's the code (first 50 lines):
<?php require_once("../../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (isset($_POST["Securelogin_submit"]) && !isset($_GET["invalid"])) {
$WAFV_Redirect = "test.php?invalid=true";
$_SESSION['WAVT_test_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
WAValidateEM((isset($_POST["Log_in_group_Email_address"])?$_POST["Log_in_group_Email_address"]:"") . "",true,1)
WAValidateRQ((isset($_POST["Log_in_group_Password"])?$_POST["Log_in_group_Password"]:"") . "",true,2)
WAValidateLE((strtolower(isset($_POST["Log_in_group_Security_code"])?$_POST["Log_in_group_Security_code"]:"")) . "",((isset($_SESSION["captcha_Log_in_group_Security_code"]))?strtolower($_SESSION["captcha_Log_in_group_Security_code"]):"") . "",true,3)
WAValidateLE((isset($_POST["Log_in_group_nbsp"])?$_POST["Log_in_group_nbsp"]:"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,4)
WAValidateRX((isset($_POST["HiddenFields_fields"])?$_POST["HiddenFields_fields"]:"") . "","/.*/",false,5)
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"test");
<head>
<link href="../../SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<script src="../../SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="../../CSSFormBuilder/WA_ServerValidation.js" type="text/javascript"></script>
<link href="../../SpryAssets/SpryValidationPassword.css" rel="stylesheet" type="text/css" />
<script src="../../SpryAssets/SpryValidationPassword.js" type="text/javascript"></script>
<link href="../../CSSFormBuilder/FD_NewFromBlank_Default.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form class="NewFromBlank_Default" id="Securelogin_NewFromBlank_Default" name="Securelogin_NewFromBlank_Default" method="post" action="test.php">
WebAssist CSS Form Builder - Form v1
CC: Log in
CP: Secure log in
TC: <New From Blank>
TP: Default
<ul class="NewFromBlank_Default">
<li>
<fieldset class="NewFromBlank_Default" id="Log_in">
<legend class="groupHeader">Log in</legend>
<ul class="formList">
<li class="formItem"> <span class="fieldsetDescription"> Required * </span> </li>
<div class="formGroup">
<div class="lineGroup">
<div class="fullColumnGroup">
<label for="Log_in_group_Email_address" class="sublabel" > Email address<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Log_in_group_Email_address_Spry">
<input id="Log_in_group_Email_address" name="Log_in_group_Email_address" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("test","Log_in_group_Email_address"):"")); ?>" class="formTextfield_Large" tabindex="1" onblur="hideServerError('Log_in_group_Email_address_ServerError');"/>
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldRequiredMsg">Please enter your email address.</span> </span>
if (ValidatedField('test','test')) {
if ((strpos((",".ValidatedField("test","test").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Log_in_group_Email_address_ServerError">Please enter your email address.</span>
<?php //WAFV_Conditional test.php test(1:)
</div>
</div>
</div>
</div>
</div>
<label for="Log_in_group_Password" class="sublabel" > Password<span class="requiredIndicator">&nbsp;*</span></label>
<div class="fieldGroup"> <span id="Log_in_group_Password_Spry">
<input id="Log_in_group_Password" name="Log_in_group_Password" type="password" value="<?php echo((isset($_GET["invalid"])?ValidatedField("test","Log_in_group_Password"):"")); ?>" class="formPasswordfield_Large" tabindex="2" onblur="hideServerError('Log_in_group_Password_ServerError');"/>
<span class="passwordRequiredMsg">Please enter a password.</span> </span>
if ((strpos((",".ValidatedField("test","test").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Log_in_group_Password_ServerError">Please enter a password.</span>
<?php //WAFV_Conditional test.php test(2:)
</div>
</div>
</div>
</div>
</div>
</div>
</li>
<div class="columnGroup">
<label for="Log_in_group_Security_code" class="sublabel" >&nbsp;</label>
<div class="fieldGroup"> <img src="../../WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Log_in_group_Security_code&font=Fonts/MOM_T___.TTF" alt="Security Code" class="Captcha" /> </div>
</div>
</div>
</div>
<div class="columnGroup" style="clear:left;">
<label for="Log_in_group_Security_code" class="sublabel" > Security code<span class="requiredIndicator">&nbsp;*</span></label>
<div class="fieldGroup"> <span id="Log_in_group_Security_code_Spry">
<input id="Log_in_group_Security_code" name="Log_in_group_Security_code" type="text" value="" class="formTextfield_Large" tabindex="3" onblur="hideServerError('Log_in_group_Security_code_ServerError');"/>
<span class="textfieldRequiredMsg">Entered text does not match; please try again</span> </span>
if ((strpos((",".ValidatedField("test","test").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Log_in_group_Security_code_ServerError">Entered text does not match; please try again</span>
<?php //WAFV_Conditional test.php test(3:)
</div>
</div>
</div>
</div>
</div>
<div class="wideColumnGroup">
<label for="Log_in_group_nbsp" class="sublabel" >&nbsp;</label>
<div class="fieldGroup"> <span class="precedingText">
<?php require_once("../../WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php"); ?>
Interesting, I'm going to open a support ticket so we can look into the problem a bit further. To view and edit your support ticket, log into your support history:
openwavecomp001387788
Two plugins are conflicting with my menu dropdowns.
When they're activated, I am unable to see the submenu dropdowns unless I navigate to the top page of that group. Plugins are Eshop and Formbuilder.
Previously, I'd simply uninstalled the plugins, however they will be required on the site, so I need to find a way for the page menu dropdowns to display with those 2 plugins activated.
You need to open a new ticket for this problem, this is not part of the problem this post was created form.
When posting your new ticket, please include screen shots demonstrating the problem or a link where we can see the problem occur.
