Creating & accessing arrays from MySQLi Recordsets
Thread begun 3/18/2016 4:46 am by Dave Buchholz | Last modified 3/21/2016 3:49 pm by Ray Borduin | 2280 views | 4 replies |
Dave BuchholzBeta Tester
so my recordset looks like this
$rsDataSet = new WA_MySQLi_RS("rsDataSet",$connMySQLi,5);
$rsDataSet->setQuery("SELECT tbl_products.pkSKU, tbl_products.CommonBrandName, tbl_products.ModelDescription, tbl_products.SKU, tbl_products.ColorDescription, tbl_products.MSRP FROM tbl_products");
$rsDataSet->execute();
Doing a print_r on $rsDataSet shows me that the recordset results are held in an array called Results:
print '<pre>';
print_r($rsDataSet);
print '</pre>';
WA_MySQLi_RS Object
[Connection] => mysqli Object
[affected_rows] => -1
[client_info] => 5.5.42
[client_version] => 50542
[connect_errno] => 0
[connect_error] =>
[errno] => 0
[error] =>
[field_count] => 6
[host_info] => Localhost via UNIX socket
[info] =>
[insert_id] => 0
[server_info] => 5.5.42
[server_version] => 50542
[stat] => Uptime: 251213 Threads: 7 Questions: 12860 Slow queries: 0 Opens: 216 Flush tables: 1 Open tables: 209 Queries per second avg: 0.051
[sqlstate] => 00000
[protocol_version] => 10
[thread_id] => 138
[warning_count] => 0
[CurrentPage] => /test-files/mysqli/index.php
[Debug] => 1
[FilterValues] => Array
[Index] => 0
[LastRow] => 15
[MaxRows] => 5
[Name] => rsDataSet
[NextPage] => 3
[PageNum] => 2
[ParamTypes] => Array
[ParamValues] => Array
[ParamDefaults] => Array
[0] => -1
[1] => -1
[2] => -1
[3] => -1
[PrevPage] => 1
[QueryString] => &totalRows_rsDataSet=207
[Results] => Array
[0] => Array
[pkSKU] => 128879
[CommonBrandName] => Weber
[ModelDescription] => Performer® Silver Charcoal Grill
[SKU] => 1401001
[ColorDescription] => Black
[MSRP] => 0.00
[1] => Array
[pkSKU] => 127609
[ModelDescription] => Performer® Charcoal Grill
[SKU] => 1411001BK
[MSRP] => 0.00
[2] => Array
[pkSKU] => 105603
[SKU] => 1421001PERF
[MSRP] => 0.00
[3] => Array
[pkSKU] => 112433
[SKU] => 1424001
[ColorDescription] => Brick Red
[MSRP] => 0.00
[4] => Array
[pkSKU] => 112434
[SKU] => 1427001
[ColorDescription] => Green
[MSRP] => 0.00
[StartLimit] => 10
[StartRow] => 11
[Statement] => SELECT tbl_products.pkSKU, tbl_products.CommonBrandName, tbl_products.ModelDescription, tbl_products.SKU, tbl_products.ColorDescription, tbl_products.MSRP FROM tbl_products
[Table] =>
[TotalPages] => 41
[TotalRows] => 207
And I have found I can create an array like so:
$DataSet = $rsDataSet->Results;
But what I would like to do if possible is create an array using only one of the fields, pkSKU in this case but I can't seem to get the code correct, is this possible and if so how do I access it ?
Hey Dave long time since we last spoke. I wondered if you could use something like what I have done (obviously my code was for a different purpose but its taking a single field from a recordset as an array and outputting it. I wondered if taking a look at my code and seeing how it works can help you solve your question?
<?php require_once('../Connections/ecartdb.php'); ?>
require_once('../webassist/mysqli/rsobj.php'); ?>
header
('Content-Type: text/csv; charset=utf-8');
header('Content-Disposition: attachment; filename=emails.csv');
$output = fopen('php://output', 'w');
$rows = new WA_MySQLi_RS("rows",$ecartdb,0);
$rows->setQuery("SELECT NewsLetterEmail FROM newsletter");
$rows->execute();
while(!
$rows->atEnd()) {
$row = array($rows->getColumnVal("NewsLetterEmail"));
fputcsv($output, $row);
$rows->moveNext();
$rows->moveFirst(); //return RS to first record
Regards
Chris
Hi Chris, hope you are well.
I am looking to see if I can use the "shorthand" method rather than having to loop through the recordset to create the array but thanks for your input.
You could loop through the Results array directly like:
$pkSKUArray
= array();
for (
$x=0; $x<sizeof($rsDataSet->Results); $x++) {
$pkSKUArray[] = $rsDataSet->Results[$x]['pkSKU'];
now why didn't I think of that, thank you Ray that is exactly what I am looking for.
