MAMP, PHP, Dreamweaver CS5.5, mySQLi, and a Mac
Thread begun 3/17/2016 5:03 pm by movygirl244169 | Last modified 3/21/2016 10:34 am by Ray Borduin | 1908 views | 1 replies |
movygirl244169
I built a site 5 years ago and it will not work on the new cPanal hosting sites. Apparently I have to rebuild every page and I purchased mySQLi to help me get things to work. However when I try to build a connection to the database I get the following: "Your PHP server doesn't have the mySQL or mySQLi module loaded or you can't use the mysql_(p) connect function." I've been trying to figure it out on the forum but I'm not able to understand what I'm suppose to do to get it working. Everything is for Windows not Mac. If anyone has a way to help me with this I would appreciate it because I'm about ready to wring my own neck just to get out of this project.
You can probably just enable mySQL from your php.ini file.
If you find your active php.ini file and find these lines:
extension=php_mysql.dll
extension=php_mysqli.dll
They probably have a semi-colon in front of them (disabled) and you just have to remove the semi-colon and restart the server.
