I'm getting a parameter error from the webassist/mysqli/rsobj.php file
Thread begun 3/17/2016 8:47 am by Jason | Last modified 3/17/2016 3:09 pm by Ray Borduin | 5341 views | 8 replies |
Jason
I'm getting this error:
PHP Warning: mysqli_num_fields() expects parameter 1 to be mysqli_result, boolean given in /public_html/webassist/mysqli/rsobj.php on line 233
I can't see exactly which file is creating the error, only the folder that contains this error log. How can I figure out which file is causing this issue?
This is an error in your SQL syntax. The most recent version of the extension should have a Debug Mode you can turn on to see the complete message... what is the SQL statement you have for that Recordset? I may be able to spot the problem.
Jason
I have to set "big selects" on my server and this was the only way I knew to get it to work. I'm not sending any params though, so I'm unsure why it's throwing an error?
$BIG_SELECTS
= new WA_MySQLi_RS("BIG_SELECTS",$local_i,0);
$BIG_SELECTS->setQuery("SET SESSION SQL_BIG_SELECTS = 1");
$BIG_SELECTS->execute();
That won't work. The RS object needs to have a SELECT statement that returns a result. The SQL you are using is causing an error.
You might be able to use something like:
SELECT (SET SESSION SQL_BIG_SELECTS = 1) AS ResultVal
But you would have to test it in your phpMyAdmin and make sure since I'm not familiar with using SET SESSION calls in general in MySQL.
Jason
This post has been deleted.
Jason
Nope, that throws an error.
Try using the query object instead of the Recordset:
$BIG_SELECTS = new WA_MySQLi_Query($local_i);
$BIG_SELECTS->Statement = "SET SESSION SQL_BIG_SELECTS = 1";
Jason
That looks like it's going to work. At least it's working on my testing server. Won't be able to test it on the live server for a day or two. What is the queryobj used for in the plugin?
Insert, Update, and Delete Queries
