Operand should contain 1 column(s)
Thread begun 3/15/2016 2:42 pm by Kumel | Last modified 3/28/2016 9:03 am by Ray Borduin | 52195 views | 22 replies |
Kumel
Wierd error: Operand should contain 1 column(s)
This is appearing after i added
AND UserGroupID = (2,11)
mysql_select_db($database_con1, $con1);
$query_Employees = "SELECT * FROM Users WHERE ID IN (".$row_UsersMachines['EmpID'].") AND UserGroupID = (2,11)";
$Employees = mysql_query($query_Employees, $con1) or die(mysql_error());
$row_Employees = mysql_fetch_assoc($Employees);
$totalRows_Employees = mysql_num_rows($Employees);
The results of these are not shown. When i remove AND UserGroupID = (2,11) results are shown. But i need this filter that UserGroupID must be 2 or 11.
File attached.
That should be: AND UserGroupID IN (2,11)
Kumel
AND UserGroup IN (2,11)?
U mean AND UserGroupID?
I tried both .. didnt work..
If i do UserGroup says wrong column & UserGroupID then
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1
Kumel
Under User Table there is :
Name, Email, UserGroupID
Yes UserGroupID.... you can't pass multiple values with an '=' comparison... you need to use IN if you want to pass more than one value comma separated.
Kumel
Getting this error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1
Write your SQL statement to the page and see what it looks like:
$query_Employees = "SELECT * FROM Users WHERE ID IN (".$row_UsersMachines['EmpID'].") AND UserGroupID IN (2,11)";
die($query_Employees);
My guess is that the UsersMachines Recordset isn't returning a result.
Kumel
FYI the RS is within repeat region of UsersMachine.
I tried as above. Error :
SELECT * FROM Users WHERE ID IN (6) AND UserGroupID IN (2,11)
UserMachine RS:
$colname_UsersMachines = "-1";
if (isset($_POST['validation-classic-machine'])) {
$colname_UsersMachines = $_POST['validation-classic-machine'];
$query_UsersMachines = sprintf("SELECT * FROM UsersMachines WHERE MachineID = %s", GetSQLValueString($colname_UsersMachines, "int"));
$UsersMachines = mysql_query($query_UsersMachines, $con1) or die(mysql_error());
$row_UsersMachines = mysql_fetch_assoc($UsersMachines);
$totalRows_UsersMachines = mysql_num_rows($UsersMachines);
It is using form post to filter with MachineID.. UserMachine is a relational-table of .
That looks like a good SQL statement to me. I'm not sure why it would error. Is it possible a different recordset is throwing the error?
Try cutting and pasting that SQL statement into phpMyAdmin and see if it works.
Kumel
But a if (isset($_POST['validation-classic-machine'])) {
post value is required. There are 2 RS.
File attached
