Validate to accept UK phone numbers only
Thread begun 3/14/2016 8:52 am by s.joiner74419001 | Last modified 2/28/2018 10:09 am by Ray Borduin | 4652 views | 10 replies |
s.joiner74419001
I am wanting to validate a form field to accept UK phone numbers only and I assume I need to use regular expressions to achieve this but I am alien to using regular expressions. Subsequently I found websites with examples to use. I have tried the following:
"/^(\+44\s?7\d{3}|\(?07\d{3}\)?)\s?\d{3}\s?\d{3}$/"
But it doesn't seem to work.
It supposedly should accept the following.
07222 555555
(07222) 555555
+44 7222 555 555
Any ideas as to where I am going wrong?
I've attached the page if it helps.
Thanks in advance.
You don't need the open and close pattern indicators... the pattern should just be:
Justin@AdventDesign
Accept UK and US numbers
Hi Ray - this should be a quick one... my client wants to add support for UK phone number validation in addition to US numbers. Currently the validation pattern reads "\(\d{3}\) \d{3}[\-]\d{4}". I'm assuming I can modify it with the UK pattern in this thread, however I'm unsure how to do an either/or scenario so that both of these patterns will be acceptable.
I think you should be able to just separate them with an "|" symbol.
Something like:
"(\+44\s?7\d{3}|\(?07\d{3}\)?)\s?\d{3}\s?\d{3}|\(\d{3}\) \d{3}[\-]\d{4}"
You would probably have to remove the formatting options if it is auto-formatting to add parenthesis as well.
Justin@AdventDesign
It appears to be doing the auto formatting to add parenthesis. How do I turn off auto formatting?
Odd thing I noticed too when poking around. The Server Validation for Phone Number was set to "Allow international", yet it wouldn't accept anything other than US 3+3+4 numbered format.
Remove the onblur code in the html input field. The client validation was forcing US format even though the server validation would have allowed international if it got there.
Justin@AdventDesign
Thanks Ray! I think we've got it nailed down.
Justin@AdventDesign
Sorry to ping you on this one again Ray but I've tried this six ways to Sunday and still have yet to get the validation to work. I'm about ready to just drop the validation and make it a simple required field, but it would be nice to at least confirm that it is plausibly a valid phone number.
I've pulled the 'onblur' as suggested, and tried both leaving the WA validation as a phone number, as well as switching it to a regular expression using the combined regular expression you suggested. The validation gets flagged regardless of what I try.
I think part of my frustration here, as with many of these issues I run into, is I don't know how to get sufficient troubleshooting information. I'm guessing there's a way to actually print some detailed information on the validation error, but I haven't found a way to do it.
PM'ing you with the page and link in case you have any other suggestions.
The syntax for regular expressions on client and server are a little different. In the server field I think you need to encapsulate it with slashes like:
/(\+44\s?7\d{3}|\(?07\d{3}\)?)\s?\d{3}\s?\d{3}|\(?\d{3}\)?\s?\d{3}[\-]?\d{4}/
I'd use the original phone validation for the server. Your client validation is working, but it is very specific and without the auto-formatting it might be difficult for people to enter the correct value.
For instance if they enter a US phone number they would need to type: (222) 333-4444
If any spaces, dashes or parenthesis are missing it wouldn't pass.
A better regular expression might be:
That would at least allow them to omit the parenthesis, dash, and space
Justin@AdventDesign
I'm unclear as to which part is server vs client validation. Is the stuff on line 25 the server, and the the code within the HTML tag for client validation?
