ecart summary problem
Thread begun 3/07/2016 11:50 am by QuiruNet | Last modified 3/08/2016 9:26 am by Ray Borduin | 784 views | 1 replies |
QuiruNet
hi, when i am trying to make the operation to store cart summary and details into the data base, it doesnt safe the details in the database. I use as a ivoce number the date. Can you help me. Thanks
Is the n_pedido field defined as the primary key field in the database? You have to choose the actual primary key field, not just any field you want to use as the key.
I'd need to debug this one as well. If you can put it on a live server I can test and debug. If you want to sign up for a premium support ticket I can call and do screen sharing with you to work through this and any other issues you are having.
