No "MySQLi" Database-Connection available after installing the extension
Thread begun 3/06/2016 11:00 pm by JSer44853608 | Last modified 10/19/2016 10:48 am by Ray Borduin | 4912 views | 8 replies |
JSer44853608
I cant select ´"mysqli" at database connection, There is only mysql available and at the main menu at webassist there is only database->model database but no more to select
i'm using DW CS4
Did the secondary installer run after you installed? It looks like the installation might not have completed properly.
JSer44853608
you mean the window with step 1 2 3 klick done and restart...yes this execute with no error
I'll have to debug this with you over the phone to see why the install didn't work properly. Please post back with a US phone number or Skype contact information and I'll get in contact with you.
JSer44853608
send you my skype informations as PM
I've added you to my Skype contacts. Please send me a message there and we can coordinate a meeting.
Massimo
I have the same problem.
Mysqli recordset wizard not show me the connection made with dinamic mysql connection.
All work with normal dw behavior
need help
Did you try opening and closing dreamweaver? Or clicking the refresh icon in the database panel?
Massimo
None of these was the problem. I created a new connection and all work. This solved for me
For some mysterious reason does not recognize the old connection.
Thanks again for the immediate assistance
and be quick with updates :)
