outputting cookie array of IDs
Thread begun 3/06/2016 12:36 pm by Christopher West | Last modified 3/23/2016 11:56 am by Ray Borduin | 7943 views | 18 replies |
Hi, a while back I asked about using cookies to display "last viewed products slider"
I almost got it working, however its only displaying 1 cookie. so the problem looks like on the page that sets the cookie (its is overwriting the previously saved cookie) how can I store it all in an array which I can then output on my other pages (also not storing any duplicate IDs)
I think on the product detail page I need to save the product ID into a string array (check so its not a duplicate) and then after save the string array into a cookie. then on the in the recordset that accesses the cookie I need to access the array and output it as a products.
On the page that displays all last viewed products:
$rsViewedProducts
= new WA_MySQLi_RS("rsViewedProducts",$ecartdb,1);
$rsViewedProducts->setQuery("SELECT * FROM products WHERE ProductID = ?");
$rsViewedProducts->bindParam("i""".(isset($_COOKIE['ViewedProducts'])?$_COOKIE['ViewedProducts']:"")  ."""-1"); //colname
$rsViewedProducts->execute();
while(!$rsViewedProducts->atEnd()) {
        <a href="product.php?Product=<?php echo($rsViewedProducts->getColumnVal("ProductName")); ?>" class="b-link-fade b-animate-go">
        <div class="item4"><img  src="libra/images/<?php echo($rsViewedProducts->getColumnVal("ProductSKU")); ?>.jpg" alt=""  class="responsive-image"></div>
        <div class="b-wrapper">
          <h2 class="b-from-left b-animate b-delay03"><?php echo($rsViewedProducts->getColumnVal("ProductName")); ?></h2>
          <p class="b-from-right b-animate b-delay03">£<?php echo($rsViewedProducts->getColumnVal("ProductPrice")); ?></p>
        </div>
        </a>
$rsViewedProducts
->moveNext();
$rsViewedProducts->moveFirst(); //return RS to first record
on the page that saves a cookie
$rsProduct
= new WA_MySQLi_RS("rsProduct",$ecartdb,1);
$rsProduct->setQuery("SELECT * FROM products WHERE ProductName = ?");
$rsProduct->bindParam("s""".(isset($_GET['Product'])?$_GET['Product']:"")  ."""-1"); //colname
$rsProduct->execute();?>
if ("" == "") {
setcookie("ViewedProducts""".($rsProduct->getColumnVal("ProductID"))  .""time()+(60*60*24*30), "/""localhost"0);
You would want to save the productID values in the cookie comma-separated that way you could store more than one. Then you could use an IN instead of = to and an "il" (integer list) as the parameter type in your recordset to return all of the previously viewed products instead of just the last one.
ah just saw your reply after I was updating this post: this is what I added :
With your approach I didnt see an option for cookie comma-seperated way? See screenshot
is this part of the webassist server behaviours or is it custom code? How would I go about coding that?
It isn't an option in our server behavior. It would require hand coding.
You would check to see if the cookie had a value in an IF statement and add a comma before the value if it had a value, if not then you just set the value as it is done now. It is another issue that requires hand coding and I could help with in a premier ticket if you had difficulty pulling it off on your own. Something like:
if ("" == "") {
$newCookieVal = isset($_COOKIE['ViewedProducts'])?$_COOKIE['ViewedProducts']:"";
if ($newCookieVal) {
$newCookieVal .= ", ";
$newCookieVal .= $rsProduct->getColumnVal("ProductID");
setcookie("ViewedProducts", "".$newCookieVal ."", time()+(60*60*24*30), "/", "localhost", 0);
ok I will add this and try and see how it works with my code. Thanks
Hi Ray, in Firebug I can see that the product IDs are being added. however after more than 1 product IDs get added to the cookie then I get a PHP error in syntax message (whats the php debug code to see what the error relates to?)
on the page with the error my recordset is:
Which I thought would work since I selected the comma-separated list checkbox in the recordset advance tab (see screenshot)
Chris
$rsViewedProducts
$rsViewedProducts->bindParam("il""".(isset($_COOKIE['ViewedProducts'])?$_COOKIE['ViewedProducts']:"")  ."""-1"); //colname
I did change to this:
However I managed the Error in SQL syntax alert comes up if I clear the cookies. Also it doesnt display the product images just the one.
$rsViewedProducts
$rsViewedProducts->setQuery("SELECT * FROM products WHERE ProductID IN ?");
In the while loop I am using this code:
html.......................
$rsViewedProducts
->moveNext();
I think if I can just this this solved here that be brilliant as I think its almost fixed.
That second one looks correct. IN with integer list should do the trick. I'd have to debug at this point to determine the issue.
See PM
I've fixed your page and prevented repeated entries to the cookie.
The issue was in the first line of the recordset:
$rsViewedProducts = new WA_MySQLi_RS("rsViewedProducts",$ecartdb,1);
The "1" at the end is the maximum number of rows to return... updating it to 0 allows it to return all rows.
Hey Ray, when I tested it on the live server (the one you have access to) it worked. However in FireFox FireBug, if I cleared the cookie and try to access the category.php page I get the same error Error in SQL syntax.
Please could you check but clearing the cookies and see why it has that error?
Chris
