Multiple Images data record not entering
Thread began 3/05/2016 4:05 pm by Kumel | Last modified 3/08/2016 10:44 am by Ray Borduin | 1492 views | 8 replies |
Kumel
Under Products table i created MainImage, MainImageThumb, Image2, Image2Thumb, Image3, Image3Thumb.
I added 3 file upload server behaviour.
I add insert record as well. & i have linked each very well to its product's folder ie thumb folder to thumbs columns.
But when i insert only MainImage, MainImageThumb & Image2 records are entered. Not rest.
I don't know whats wrong with it.
FIle attached.
add-product.php
It looks like it should work. Can I get FTP access and a url to reproduce to debug it?
Kumel
Sorry its not online. Just on local server
Your bindings aren't right. It looks like there is a bug in the syntax it uses when there is more than one upload that has more than one version. You will probably have to correct them manually.
You have:
$WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_2"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult2"]["WA_UploadResult1_2"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult3"]["WA_UploadResult1_1"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult3"]["WA_UploadResult1_2"]["serverFileName"]
The first two are correct, which is why they work. The others are not. It should be:
$WA_DFP_UploadStatus["WA_UploadResult2"]["WA_UploadResult2_1"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult3"]["WA_UploadResult3_1"]["serverFileName"]
$WA_DFP_UploadStatus["WA_UploadResult3"]["WA_UploadResult3_2"]["serverFileName"]
I'll get the bindings fixed.
Kumel
unable to fix. i update the file. Image3 & Image3Thumb records not saving.. will be uploading in 5mins. pvt msg..
Please send a current copy of the file and I'll see if I can spot the problem.
Kumel
i just updated add-product page.
For Image2 i chose: 24.jpg
Data entered in Image2 =24.jpg & Image2Thumb = 24_thumb.jpg25.jpg25_thumb.jpg (something wrong here )
Data entered in Image3 = 1 & nothing in Image3Thumb
file attached here.
It looks like you updated the code by hand and removed the . $WA_AB_Split . code between the values so that they got concatenated into the same field.
Kumel
Perfect! Thanks
