Dynamic Menu not working
Thread begun 2/29/2016 11:46 am by Kumel | Last modified 5/10/2016 9:32 am by Ray Borduin | 5973 views | 24 replies |
Kumel
I have added a new column called Menu in UserGroup cause in my current project i have different types of users for every different type of user has different menu options.
One of the results in UserGroup column Menu contains php value which is:
<img src="../images/employees/<?php echo $row_UserDetails['Image'];?>" alt="">
The Recordsets are:
<!-- User details -->
$colname_UserDetails = "-1";
if (isset($_SESSION['SecurityAssist_ID'])) {
$colname_UserDetails = $_SESSION['SecurityAssist_ID'];
mysql_select_db($database_con1, $con1);
$query_UserDetails = sprintf("SELECT * FROM Users WHERE ID = %s", GetSQLValueString($colname_UserDetails, "int"));
$UserDetails = mysql_query($query_UserDetails, $con1) or die(mysql_error());
$row_UserDetails = mysql_fetch_assoc($UserDetails);
$totalRows_UserDetails = mysql_num_rows($UserDetails);
<!-- User Type & Menu -->
$query_UserGroup = "SELECT * FROM UserGroup WHERE ID IN (".$row_UserDetails['UserGroupID'].")";
$UserGroup = mysql_query($query_UserGroup, $con1) or die(mysql_error());
$row_UserGroup = mysql_fetch_assoc($UserGroup);
$totalRows_UserGroup = mysql_num_rows($UserGroup);
Menu is displayed like this: <?php echo $row_UserGroup['TopHeader'];?> (menu)
So to display result of UserDetails['Image'] does not support is it?
The correct syntax is the first one you referenced:
You maybe just need to start the session on the top of the page:
@session_start();
Try writing the sql statement for that recordset on the page and see if you can spot the problem:
echo($query_UserDetails);
Kumel
When i use
i check on img placeholder doesnt display imge. but link of it is:
http://localhost/**/images/employees/%3C?php%20echo%20$row_UserDetails['Image'];?%3E
it must display: http://localhost/**/images/employees/filename.jpg
gives: SELECT * FROM Users WHERE ID = 14
The problem is <?php echo $row_UserDetails['Image'];?> this is not display value from recordset. y?
Can I see a copy of the page?
Kumel
file attached. copy of db structure of UesrGroup also attached
It looks correct to me. Can I see the live URL where you are having problems? I can't spot an issue in this file.
Kumel
its on my local server.
But i feel php eco $row.. values doesn't let you display from mysql if stored like that.
Yes it definitely does let you display code with echo. I've done it hundreds of times. The code you referenced from the page looks like you pasted it into design view instead of code view... but the code on the page you attached looks correct.
Kumel
So any solutions or any other way?
I have to work with the page to see what is going on. If you can put it on a live url I can take a look. I don't see any issue with the code you supplied. I may be overlooking something, but I can't imagine what it would be.
If I could view the error on a live site and debug it then I'm sure I could figure it out, but as it is I don't have a solution since I don't see a problem.
