Login Redirect to wrong page
Thread begun 2/29/2016 11:11 am by Kumel | Last modified 2/29/2016 3:44 pm by Ray Borduin | 1912 views | 3 replies |
Kumel
I have many pages that can be opened after login. After once user logs in he is taken to dashboard.php from login page. But all of a sudden it redirects to wrong page which i don't want anytime anyone to be redirected to. Its a jquery based page(job-notification.php) which works on background for data retrieval on dashboard page(dashboard.php).. When i click logout & login using different id then it still takes me to job-notifcation.php.
But i crossed checked login.php page sucessredirect is dashboard.php
Is the jquery causing problem to this?
pages attached.
At login.php "successRedirect" => "latest/dashboard.php?loggedIn=1",
Its correct cause dashboard.php page is on folder called latest & also is job-notification in latest folder. (FYI)
The only place I see a reference to job-notification.php is on the dashboard in the javascript on line 219. If you remove that script does it still redirect to that page? I'm thinking that has to be doing it for some reason.
If you just type in the url: latest/dashboard.php?loggedIn=1 does it take you to the page? I'd debug it that way. It doesn't appear to be an issue with the login code.
Kumel
i added this on login.php start:
@session_start();
@session_start();
if ("" == ""){
// WA_ClearSession
$clearAll = TRUE;
$clearThese = explode(",","");
if($clearAll){
foreach ($_SESSION as $key => $value){
unset($_SESSION[$key]);
else{
foreach($clearThese as $value){
unset($_SESSION[$value]);
seems fine now.. No problem with it right?
No problem with that code. I'm confused about why that helped, but I guess if it works go with it.
