Contact Form
Thread begun 2/23/2016 6:20 am by rob294118 | Last modified 2/23/2016 4:44 pm by Ray Borduin | 4934 views | 19 replies |
rob294118
Contact Form
I created a form and set the list-style to none but I am still getting bullets on my form. It is not submitting the form to me either. Also does not redirect to my thankyou.php page after the form submits.
I have other forms that are working on this website.
http://www.rottrescuela.org/contact-us.php
The "bullets" you see aren't added by the list-style...they are added on style.css line 1914:
.art-postcontent ul > li::before, .art-post ul > li::before, .art-textblock ul > li::before {
bottom: 2px;
content: url("images/postbullets.png");
display: inline-block;
font-size: 0;
line-height: 0;
margin-right: 6px;
position: relative;
vertical-align: middle;
You can override that code with something like:
.art-postcontent form ul > li::before {
display: none;
You aren't getting the form submission because the server validation is still looking for form fields "Best_Day" and "Best_Time", which you must have removed at some point. You'll have to remove them from the server validation as well, that can be done by deleting lines 15,16 manually or from within the Server Validations Server Behavior UI.
Please post new messages instead of revising the old one, it makes it difficult for others to follow if they end up having similar issues in the future.
If it takes you to the thank you page now, then it is trying to send the email. What do you have the "FROM" address set to in the email server behavior.
rob294118
"FROM" address
Is this what you mean?
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
No... What I mean is what value did you put into the Email Server Behavior for the from field?
rob294118
I have no idea what you mean. This?
<?php echo ((isset($_POST["Email_Address"]))?$_POST["Email_Address"]:""); ?>
OK, and what did you enter in the form when you tested for the email address?
It is usually not a good idea to actually send the email FROM the entered value because of the high probability of a SPAM check failure. Since the email really isn't coming FROM that person's email server. Try setting the FROM to a valid email address registered on the server sending the email and it may improve the deliver-ability. You can set the Reply-To to the email field from the form separately by clicking the FROM button in the UI and setting it to a separate value.
rob294118
I entered my email address. I tried another one too. It doesn't work.
I have no idea what you're talking about. I have other forms on this website that work. I'm doing exactly the same thing on the contact form but it doesn't work!
Can you give me FTP access to your files? That would allow me to debug further.
rob294118
What files can I send you. I don't know the FTP info right now and I need this fixed.
