upload file names
Thread begun 2/19/2016 6:21 am by Jamie | Last modified 3/11/2016 2:46 pm by Ray Borduin | 4479 views | 14 replies |
Jamie
upload file names
Hey Ray
How would you go about stopping a file upload that has a file name with spaces and/or 'illegal' characters?
Cheers
Jamie
You can use server validation to validate the name.
Jamie
ok gotcha. with the alphanumeric option, if I wanted to add - and _ in the additional field, do they need to be comma separated ?
no, just listed
Jamie
Ok cool thanks. Also, due to the laptop dpi issue, I can't see what the checkbox is for below the additional options ....
"Allow blank"
Jamie
Thanks Ray. Have tried to do this on an insert page that requires the user to add a main image and the option to add 4 further sub images.
However, the validation is failing on the optional sub images even when the main image is ok.
Have attached the insert page
It looks like you didn't check the "allow blank" option for the fields you want optional.
the final "true" in those lines needs to be "false".. so line 31 would end with: false,6);
Jamie
ah ok thanks.
now the main image is failing validation regardless if the file name is 'good' or not.....
That is probably because the image always has a "." in it and you aren't allowing the "."
