Mysql database require_once connection error message
Thread begun 2/17/2016 10:56 am by tmcbinc99963 | Last modified 2/17/2016 1:03 pm by Ray Borduin | 2406 views | 4 replies |
tmcbinc99963
I've developed the following connection error after creating a dwt template in both the php page and the template page. Not sure if it's related or not:
Warning: require_once(Connections/PrimroseDb.php): failed to open stream: No such file or directory in /Applications/MAMP/htdocs/primrose.com/Products2.php on line 7
Fatal error: require_once(): Failed opening required 'Connections/PrimroseDb.php' (include_path='.:/Applications/MAMP/bin/php/php5.6.2/lib/php') in /Applications/MAMP/htdocs/primrose.com/Products2.php on line 7
I can successfully access and test both the Db and associated record sets on both pages.
I'm trying to correct this so I can use Framework Builder to turn my dwt into a theme. Will the theme allow me free use of php? I read on a WA post that dw templates won't allow php on both templates and pages using those templates.
Zip attachment included. Error pages are TemplateB and Products2.php. Let me know if you don't get the attachments; lately I've had trouble uploading files for some reason. The attachment file never shows up anywhere, so I can't tell if it has uploaded.
It looks like your include path didn't get updated correctly. It probably needs to be updated to: ../Connections now that the template file is in the Templates sub directory.
tmcbinc99963
It already uses ../Connections. The error is not only on the template page, but also on the php page the template was created from.
The error says the file: "Connections/PrimroseDb.php" doesn't exist... did you maybe not upload it?
tmcbinc99963
I found the error - the Db name in the require_once code was different than the Db name created in DW. Sorry to bother you for such an obvious mistake.
