Not understanding
Thread begun 2/16/2016 9:50 pm by Warrio | Last modified 2/25/2016 12:41 pm by Ray Borduin | 4360 views | 19 replies |
Warrio
Not understanding
I created a very simple local checkout on one site, no fields just hard coded data with a single button which worked.
I copied over to another site and it worked when submitted to the sandbox
I then opened the local checkout server behaviour to start mapping to fields.
NO changes were made to the behavior just closed it and submitted it.
Now i throws an error, the only thing done was to open and close the server behaviour
The key error is:
Security header is not valid
this means the username, password, or signature are not correct. Perhaps it didn't keep the sandbox setting and it is submitting to the live server now. That would explain the issue since they use different credentials.
Warrio
Thanks Ray, I've actually removed the variable from the page and hard coded use sandbox to "true".
I'll do it again and see what happens
Cheers
Warrio
I went to gateways and made the sandbox log in both test and non test the same.
Tested again and it failed.
copied the page to another site and it works!
Any idea?
Cheers
Norman
I'm thinking it is submitting to the live server, so updating both to the sandbox wouldn't help.
Try getting and using live credentials.
Warrio
Hi Ray,
it worked sending it to PayPal, the question now is why the test setup works in one site and not the other.
Why would site 2 not be using the sandbox url when I've hard coded
$PP_DirectPayment_required[0][$nextIndex] = "UseSandbox";
$PP_DirectPayment_required[1][$nextIndex] = "true";
the only other file is require_once("WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php");
I think maybe it is supposed to be:
$PP_DirectPayment_required[1][$nextIndex] = true;
Warrio
I made a copy of PP_Direct Payment and replaced the same file from the working site.
FIXED!
Warrio
Hey Ray,
The only way I can get the sandbox to work with the local checkout is to hard code the authentication details into the page.
If I use the gateway include, it comes up with.
LongMessage xsi:type="xs:string">Security header is not valid</LongMessage>
It's trying to send it off to PayPal not Sandbox
Any ideas
Cheers
If you send me FTP access and a URL where I can debug it then I can test and debug to figure out what is going wrong.
