Before page loads form =get
Thread begun 2/16/2016 4:10 am by Kumel | Last modified 3/02/2016 1:00 pm by Ray Borduin | 4442 views | 9 replies |
Kumel
I have a page called notifications here all notifications are displaying thru db!
Notifications columns are: ID, UserId, SenderId, TimeAdded, UnRead & JobiD.
All values are added except unread = 0.
I want to turn this value to 1 as user clicks on the notification. As he clicks he is taken to a job details page about the notification & other details.
Now on details page i used link like this: ../job-details.php?JobID=213&NotificationID=5 (This means the person has clicked on notification which ID is 5 & JobID is 213 which currently is displaying details on JobID=213. As as person visits this page i have made a form in job-details.php page as :
<form name="notifications" action="job-details.php" method="post">
<input name="NotificationID" type="hidden" value="<?php echo((isset($_GET["NotificationID"]))?$_GET["NotificationID"]:"") ?>" />
</form>
I added update record server variable here using data assist As NotificationID as key value for table Notifications & setting trigger as before page loads & in binding choosing UnRead as 1 as value. But it doesnt work. But if a add a submit button & change trigger to on submit then it doesnt work.
How to make this work on Before page load?
I'd need to see the code. It is probably that you have the update record ID set to: <?php echo((isset($_POST["NotificationID"]))?$_POST["NotificationID"]:"") ?>
and it should be: <?php echo((isset($_GET["NotificationID"]))?$_GET["NotificationID"]:"") ?> in order to work before page load.
Kumel
yeas Its GET itself. Anyways page attached.
I don't see any update code on this page at all. Set it up to update before page loads and then send me that page as you have set it up so I can debug what might be wrong.
Kumel
there is update record just above the form
Just as I suggested you have the Key Column value set to:
<?php echo ((isset($_POST["NotificationID"]))?$_POST["NotificationID"]:""); ?>
and it needs to be:
<?php echo ((isset($_GET["NotificationID"]))?$_GET["NotificationID"]:""); ?>
Kumel
it is : <input name="NotificationID" type="hidden" value="<?php echo((isset($_GET["NotificationID"]))?$_GET["NotificationID"]:"") ?>" />
Kumel
oh grt. i thought your saying in text field. just changed on update record. thnks
Kumel
@Ray. i added new RS. This is for updating time in db when it was read. This is as per Timezone from there end, this is stored in DB!
<input name="TIME" id="TIME" type="text" value="<?php date_default_timezone_set("".$row_CompanyDetails['TimeZone']."");echo "".date("Y-m-d G:i:s");?>">
So my form looks like this:
<form name="notifications" action="job-details.php" method="post" class="pull-right">
</form>
NotificationID is from URL. So then i went update record & added TIME as well..
But this doesn't upload the time into the server.
File attached. Input type may be text for now cause i was testing to see if time appears. & it does appear in page when i use type of input (TIME) as text.
You are using a trigger of "before page loads" but referring to a posted form value... the form post won't exist before the page loads because it won't have been posted.
If you want to set the value before the page loads you should be binding it directly to:
<?php echo (date("Y-m-d G:i:s"));?>
and you can add the line:
<?php date_default_timezone_set($row_CompanyDetails['TimeZone']); ?>
right above it on line 223
You can't refer to a form post in the before page loads triggered action because no form is being posted when the page loads.
