Unknown column 'C2.ContentInlineToolbar' in 'field list'
Thread begun 2/11/2016 9:44 am by russb335115 | Last modified 2/12/2016 10:24 am by Ray Borduin | 2559 views | 4 replies |
russb335115
I'm redesigning a client's website and I'm trying to connect it to their existing CMS content. When I do that and preview it I get the this error:
What do I need to do the correct this?
It sounds like they may have a different version than you. Did you replace their cms admin? The answer may be to add that column to their contents table, or remove it from the SELECT statement depending on what else you have done.
russb335115
Ray,
The original CMS was created by me using PowerCMS. What do you recommend I try?
Add the ContentInlineToolbar column to the pcms2_contents Table.
russb335115
That did it, thanks Ray.
