Validation Show If
Thread begun 2/10/2016 12:51 pm by mrobben375515 | Last modified 2/11/2016 9:11 am by Ray Borduin | 2933 views | 6 replies |
mrobben375515
Validation Show If
I have a registration page for my users. If the email already exists in the user file, I want to display the message a message to that effect. However, the regions is showing automatically which makes sense because the user has not filled out the form yet. How do I display this message after the user enters an email into the field and not on the page load?
You should be using Server Validations that comes with Data Bridge, which includes "Unique Value in Database" validation, or "Check new Username" Server behavior that comes with MySQLi Server Behaviors to do this check.
mrobben375515
I use Data Assist to create the attached registration page. I am getting the error Call to undefined function WA_Auth_RulePasses(). I am not sure what is wrong. Can you help please? The site is in the pm box.
That is a call to a security assist function and the library require_once() code isn't on the page.
you probably just have to add this to the top of the page:
<?php require_once("webassist/security_assist/helper_php.php"); ?>
mrobben375515
I have the page loading now. But I see two new issues now:
FIRST, when I enter an email that is already in the system, I get the following error:
Warning: get_class() expects parameter 1 to be object, resource given in /home/content/05/11651305/html/1to1-silpada/webassist/form_validations/wavt_scripts_php.php on line 654
Warning: Cannot modify header information - headers already sent by (output started at /home/content/05/11651305/html/1to1-silpada/webassist/form_validations/wavt_scripts_php.php:654) in /home/content/05/11651305/html/1to1-silpada/webassist/form_validations/wavt_scripts_php.php on line 85
Second, when I enter a new name successfully, I am getting the following errors:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/05/11651305/html/1to1-silpada/webassist/form_validations/wavt_scripts_php.php:654) in /home/content/05/11651305/html/1to1-silpada/registration-new.php on line 60
Try updating line 654 of: webassist/form_validations/wavt_scripts_php.php
if (is_object($conn) && get_class($conn) == "mysqli") {
It looks like some code added to make it work with mysqli is causing errors with standard mysql recordsets. I'll get it fixed in the next DataBridge update as well.
mrobben375515
Thanks Ray! That solved both issues.
