Script errors every time I open Dreamweaver from web assist extensions
Thread begun 2/10/2016 10:25 am by adicarlo384434 | Last modified 2/10/2016 3:31 pm by Ray Borduin | 1743 views | 3 replies |
adicarlo384434
Every time I open a page in Dreamweaver I receive script errors from different web assist extensions, I have to click ignore about 20 times in a row until I can actually work on the page, then as soon as i make a change to the page without even saving it it start getting same script errors again, it never stops. I have tried all the suggestions on the forum, I even tried to uninstall all extensions but in Dreamweaver the options to select the web assist extensions are still there. I have tried the following so far with no success: 1. In Dreamweaver workspace reset my developer layout 2. Deleted the Dreamweaver cache file from the users configuration folder I have tried to reboot after all attempts, should I just delete the entire web assist folder from the configuration and reinstall all web assist extensions? or do something else? Thanks, Amedeo
What are the exact errors?
A clean install of all of your extensions might be the best option.
1) Close Dreamweaver
2) Rename your Dreamweaver User Configuration folder to Configuration_bak
3) Reinstall the extensions
By renaming the Configuration folder it will effectively remove all installed extensions and clear any errors. After that a clean install should get everything working without errors again.
adicarlo384434
Thanks for quick reply Ray
Ray, actually there are 30 errors in a row, you stop counting after 20 :) 1st error comes up as soon as I start dreamweaver, the rest come up one after another after I click inside a page after i open it, too many to type out so I'm attaching screenshots of the errors numbered in the order I receive them, let me know if i should do as you mentioned above now that you can see the errors.
Thanks,
Amedeo
Yes... the errors you are getting are from very old versions of our extensions. What extensions of ours do you have installed? I think my suggestion of a fresh start is the best idea given the large number of errors you are experiencing.
