Discount Button Not Updating
Thread begun 2/05/2016 1:09 pm by mrobben375515 | Last modified 2/08/2016 9:33 am by Ray Borduin | 1334 views | 3 replies |
mrobben375515
I have the attached cart.php. When I click on the Apply Coupon If Available, the value in the form does not appear to be going the record set "Discount" to do the lookup. Any ideas what might be wrong?
You have to move your session variable code (lines 94-123) down below the recordsets that currently end on line 177.
mrobben375515
I think I did what you suggested, but the discount is still not applying. I am attaching the cart and credentials should you want to see what is going on.
mrobben375515
I was able to fix this. It is working now. Thanks!
