Discount Code Not Updating In Order Header
Thread begun 2/05/2016 5:44 am by mrobben375515 | Last modified 2/05/2016 2:12 pm by Ray Borduin | 3073 views | 6 replies |
mrobben375515
I am able to pass the discount value to the order table, however, the code used is not going in. I am using the value <?php echo $eCart1->RuleLooperValue("Discounts"); ?> to update the discount value that works. However, <?php echo $eCart1->RuleLooperName("Discounts"); ?> is not passing the name to the order header. Can you help me please? See attached for private access to site and pages.
Those functions are meant to be used within a while loop to show all discounts... What is it you are trying to do with them here? I have a feeling a different approach is necessary. What value do you want stored as the rule name? It looks like you only have one Discount rule applied. If you did get this working it will only show the first discount rule anyway it doesn't find the active one.
mrobben375515
I am trying to update the order table with the discount value and the discount code. I am using the confirm.php page and I am editing the code using the server behavior "eCart Store Summary in Database". The only options I am seeing that relate to the discount is the Rulelooper.
The code is entered and applied on the cart.php page. In my cart.php page, I do move the discount code to a session variable titled "PromoCode". However, when I click on the server behavior "eCart Store Summary in Database" I do not see that available to put into that field.
Use this:
<?php echo(isset($_SESSION['PromoCode'])?$_SESSION['PromoCode']:""); ?>
mrobben375515
Very good. Should I do this on the cart.php page or in the confirm.php page?
Wherever you want to reference the promo code being used.
mrobben375515
Never mind, I found the server behavior to clear the session variables.
