Security: default value for text recordset parameter
Thread begun 2/03/2016 1:54 am by Sweens | Last modified 2/03/2016 11:19 am by Ray Borduin | 2805 views | 6 replies |
Sweens
Hi
I'm after a bit of advice, if someone can help. I'm moving away from integer parameters in recordsets (e.g. where id = 1) to text values, as I'm trying to use friendly urls.
So a recordset might have where pg_slug = $_GET['slug']. All this works and the correct page is returned, but I'm really wanting to know if there is a potential security risk here, as I have the default value as 'hjgubjvyu64565dx' (or similar random guff). Should the default text value be % or something else - or does it not matter?
Many thanks
Chris
I'm not sure what code you are using exactly, so I can't comment on a security risk. That default value will presumably not return any results, so there is no security risk in that particular aspect.
Sweens
Thanks Ray
I'm using variants on:
$rsPageMenu = new WA_MySQLi_RS("rsPageMenu",$connSite_i,0);
$rsPageMenu->setQuery("SELECT `pages`.`PgID`, `pages`.`PgTitle`, `pages`.`SiteID`, `pages`.`PgDesc`, `pages`.`MemOnly`, `pages`.`pg_url`, `sites`.`short_url`, pages.PgMainPic, pages.PgMainPicAltText FROM `pages` Inner Join `sites` ON `sites`.`SiteID` = `pages`.`SiteID` WHERE `sites`.`short_url`=? AND pages.UnderPag_PgID = 0 AND pages.PgTypeID=1 AND (pages.DisplayUntil IS NULL OR pages.DisplayUntil = '') ORDER BY pages.PgSortOrder ");
$rsPageMenu->bindParam("s", "".$_GET['su'] ."", "jhg ytokjiyr22t8cxfdxsfg"); //p1
$rsPageMenu->execute();
it's the value 'jhg ytokjiyr22t8cxfdxsfg' I'm not sure of
Cheers
Chris
There is no security issue in using that value. I usually just use "-1" since presumably you would never have that as the short_url, but really any value that you are sure will never be in that column will work.
Sweens
Many thanks Ray. I assume that where I want the default value to be a 'real' short_url, there is no security implication?
Cheers
Chris
Nope that would be fine too... it would just mean that page would show up if the page was visited directly.
Sweens
Thanks for your help Ray - very reassuring!
Cheers
Chris
