Can't run "mysqli_escape_string" with standard Webassist settings
Thread begun 1/31/2016 7:27 am by djellis267466 | Last modified 2/08/2016 9:01 am by Ray Borduin | 3099 views | 4 replies |
djellis267466
I am trying to use the mysqli_escape_string function to escape a $_POST input. The php manual says this needs a valid mysqli connection to be in place to run.
I have the standard Webassist mysqli statements in place and I can use the Webassist Record set functionality to display records. However the mysqli_escape_string does not run.
Any thoughts ?
<?php require_once('Connections/connXXSQLi.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$p = (mysqli_escape_string($_POST['searchwords']));
The correct syntax would be:
$p = (mysqli_escape_string($connXXSQLi,$_POST['searchwords']));
djellis267466
Hi Ray, many thanks for your help. All working correctly now.
Cheers, Dave
djellis267466
Escaping $_GET input
Hi Ray, should I be using the mysqli_escape_string method to escape all $_GET input before using the data in MySQL queries ? I am unclear if the Webassist built in functions mean that this is not required.
Cheers, Dave
We use the mysqli parameters which are automatically escaped, so you don't need to use that function on passed in values.
